jsuber
juke
Jls297#40601
It’s a good suggestion! We assumed that people would know that they are the same wheelbase.
You my friend are in the selling business and if you are selling people Tacoma parts then give them confidence to spend the kind of money you are asking for. Let them know if it works for a Cat bulldozer if it works.
goin2drt
KY
At $1400 they better look great. Sadly too small to actually be good off road. This company is becoming by far the most over rated and over priced company in the industry. IMO of course which I am entitled to.
px3_taco
Michigan
How are they too small to be good off-road?
Mini2nut
My only suggestion: they need to offer buyers a black out option for the NYTOP trim plate and bolts.
NYTOP
Eric
Walnut, CA
nytop.com
2024 Tacoma TRD Off-road
Hi! The badge and top bolts are both stainless steel for longevity reasons.
You can easily remove the badge (held on by 3M tape) and also swap the M4 bolts with black ones (which tend to rust easily).
Mini2nut
bronzebeast
So Cal
2025 DCLB
Do these stick out further than the widest part of the door when it’s closed? Anyone have pics looking straight down with door closed? I like these but not quite sure they would offer enough protection from the side
Mini2nut
My order finally arrived after an 8-week waiting period. Since I live within 30 miles I opted for local pickup. The shipping boxes are overkill and helped protect the sliders during the long overseas journey from the Chinese fabrication shop.
The construction is very heavy duty. These sliders weight in at roughly 80 pounds apiece. They are heavy!!! I think these rock sliders will outlive the vehicle. If you are looking for a HD set of rock sliders you want a set of NYTOP’s.
Both sliders exhibited excellent welding and powder coating craftsmanship. All 22 mounting holes aligned perfectly with the frame holes. These bolt directly to the frame, not the thin steel rocker panels like most sliders and running boards.
The only modification I made was swapping out the bare SS bolts for some black SS bolts on the top trim piece as my exterior and Method wheels are black.
The rock sliders stick out roughly 3” from the upper edge of the rocker panel. Plenty of room for stepping when entering/exiting the vehicle.
Bottom line? ??
jimmy-buffett
Denver
'24 Tacoma SR5 Xtracab
My conundrum is finding rock sliders for my 2024 Xtracab. I waited 40 years to get a Tacoma and part of its pizzazz is the availability of aftermarket parts. Not so for us Xtracab owners.
I'm modifying a set of RCI sliders for the xtracab in the next few weeks, I'll post a thread when done.
The Xtracab is the same wheelbase and overall length as the 4-door short bed Tacoma. The first 3 mounting points are exactly the same, the body mount for the shorter cab blocks the 4th mounting point for the sliders. All they need to do is cut/remove the 4th mounting point and relocate it, which is what I'm doing.
