New K&N 63 Series Intake - Forum Exclusive Discount!
Caleb@PandaMotorworks
Caleb
St Louis MO
2021 Bronco
Your Tacoma called... it wants to breathe!
The K&N 63 Series Intake IN STOCK at Panda Motorworks, and we have a Tacoma4G Forum EXCLUSIVE DEAL for you! Get your intake for only $330 when you use code "KNNTACO". Free shipping to the US lower 48.
Treat your truck to that sweet induction sound and extra punch of performance.
K&N 2024 Toyota Tacoma 63 Series Air Intake
kn-engineering-kn-2024-toyota-tacoma-63-series-air-intake-knn63-9043-panda-motorworks-669309.jpg
kn-engineering-kn-2024-toyota-tacoma-63-series-air-intake-knn63-9043-panda-motorworks-245261.webp
This K&N cold air intake system is engineered for your Toyota Tacoma L4-2.4L Turbo F/L. A high-density polyethylene (HDPE) rotationally molded tube helps increase the volume of airflow to your engine and provides a guaranteed increase of 15.6 horsepower and 20.7 torque with no tune required. This intake system is paired with a washable, reusable High-Flow LIFETIME Air Filter™ featuring oiled cotton filter media. The oversized, conical design allows you to go up to 100,000 miles between filter services under normal highway driving conditions. A custom designed enclosed air box helps protect intake air from the high temperature of your engine bay, and the entire system can typically be installed in less than 60 minutes.
Product details
  • GUARANTEED INCREASE IN HORSEPOWER & TORQUE: K&N cold air intake systems provide a less restrictive path for airflow, increasing the volume of cool, oxygen-rich air into your engine an estimated increase up to 15.6 HP and up to 20.7 ft.lbs. of Torque
  • HEAR THE GROWL: K&N’s intake systems allow your engine to breathe and sound as it should- your engine will growl on acceleration and return to quiet once at speed
  • DYNO TESTING YOU CAN TRUST: K&N air intake horsepower/torque testing is performed on wheel-based dynamometers and the reports are include with each intake system
  • BETTER TOWING: K&N’s cold air intake kit improves acceleration and uphill performance when towing by improving throttle response and overall horsepower and torque
  • FEATURING K&N’s SIGNATURE, REUSABLE AIR FILTER: Combines 4 layers of pleated, breathable cotton with K&N’s red filter oil to absorb dirt and dust particles, allowing clean air to continue flowing into your engine, only needs cleaning every 100,000 miles
  • DURABLE ROTO-MOLDED INTAKE TUBE & CUSTOM HEAT SHIELD: A high-density polyethylene (HDPE) rotationally-molded intake tube helps increase the volume of airflow to your engine, while the heat shield helps protect intake air from the high temperature of you
  • PREMIUM ENGINE PROTECTION FROM A TRUSTED BRAND: K&N air intake will not void manufacturer vehicle warranty & No-Hassle Lifetime Limited Warranty protects for the life of your vehicle
kn-engineering-kn-2024-toyota-tacoma-63-series-air-intake-knn63-9043-panda-motorworks-174531.webp
Drifte
Colton
Iowa
24 tacoma trd offroad
Just ordered! I like that this intake replaces the entire intake from the turbo.
RonL.
Ron
Northport
I would be VERY SUSPECT of this product/company that states it only needs cleaning every 100,000 miles!
Swizzard24
Swizz
Rhode Island
2024 Tacoma Off Road
kn-engineering-kn-2024-toyota-tacoma-63-series-air-intake-knn63-9043-panda-motorworks-245261.jpg
Product details
kn-engineering-kn-2024-toyota-tacoma-63-series-air-intake-knn63-9043-panda-motorworks-174531.jpg
Wil it work with 2024 OR hybrid?
Drifte
Colton
Iowa
Car manufacturers claim lifetime transmission fluids too. Just use your best judgment. If I run a K&N oiled filter I clean it once a year. If I use a dry element filter I replaced it every few years. Never really paid attention to the miles.
SNofRANDY
Randy
Northern Nevada
2025 Tacoma TRD Off-Road, 2001 Honda S2000, 2016 Subaru Crosstrek
Got one! This is my 4th K&N intake system (04 Corolla, 01 S2000 2x) and never had any MAF fouling in any of the 3 even after washing and re-oiling. K&N makes great stuff
Astewart23
Alex
That 100,000 mile service interval is under normal conditions, check/clean/replace as necessary. If you drive in the city you could probably get away with that service interval. If you live in the mountains with plenty of dirt roads and what not in the air, you will need to check much more often.
EVOTACO
Jay
Here is what the instructions actually say. Note the cleaning more often when used in dusty/off-road environments. I've always changed my serviceable air filters every oil change by simply swapping the dirty filter with a spare clean filter and then service the dirty filter, so it is ready to use the next time.
