My i-Force Max has an.... Alternator???
james cole
Bronco
Looks to me like an alternator on my Hybrid, tought they had an electric motor generator only?
Pics or it didn't happen.
Are yours the same?
Thanks
JC
2024 Tacoma My i-Force Max has an.... Alternator??? IMG_2546
2024 Tacoma My i-Force Max has an.... Alternator??? IMG_2547
LincolnSixAlpha
Phoenix
Certainly looks like the alternator in my non hybrid OR! Since the hybrid system bolts in between the output of the engine, and input of the tranny, the motors are just built the same as non hybrids to simplify builds. Meaning you got the alternator. At least this is a guess on my part.
james cole
Bronco
yes but its not supposed to have one…
chasea1989
Chase
Las Vegas, NV
2024 Toyota Tacoma SR5
That's definitely an alternator. It might use it to keep the 12v system charged up when the hybrid battery is low. That's just speculation though. You don't see them in any of the other toyota hybrids.
Halifax, NS
2025 TRD Pro
Mine has one too I posted it on the post with people very confident we didn’t have them
2024 Tacoma My i-Force Max has an.... Alternator??? IMG_5437
Brian2011
MASS
2024 Trail hunter
The truck has a 12v battery under the seat and the ECU all use the 12v system independent of the hybrid systems. And the alternator is required; it has a generator to start the truck and charge the hybrid battery. apparently, there's a backup starter, but my truck never tried to use it after system drained.
Halifax, NS
2025 TRD Pro
it does not have a traditional starter motor it's a generator system used to start the truck and charge the hybrid battery
It’s impossible to get a picture of it, but the truck indeed has two starters, it’s explained that the truck uses the normal starter after fuel up only
2024 Tacoma My i-Force Max has an.... Alternator??? IMG_5516
james cole
Bronco
Thats strange… I have seen some that do not have alternator plus theres tons of documentation stating no alternator.
why the change?
Halifax, NS
2025 TRD Pro
Thats strange… I have seen some that do not have alternator, why the change?
There were people complaining the truck would die within 3 days of sitting, I wonder if they don't have an alternator, not that it would charge it while off lmao
Brian2011
MASS
2024 Trail hunter
My truck did not start after 4 days sitting it has an alternator; it never tried to use the backup starter motor :) voltage after 4days was 10.5 and did not even attempt to turn over, all kinds of lights on the dash and funky electric things going on like one headlight on one off etc.
Halifax, NS
2025 TRD Pro
The normal starter is only for hydro locking or something they say the hybrid motor will power through any hydro lock that COULD possibly happen during a fuel up and completely destroy the engine, so it wouldn’t engage if you didn’t fill up, that being said, I don’t know if I’ve ever heard mine but I never had the windows down after getting fuel yet since it’s been cold as hell since I got my truck
I want to test putting a tender on the 12v overnight and see if any overflow runs into the high voltage battery I don’t think that makes sense but I don’t think anyone has answered how to put a tender on these trucks yet
Brian2011
MASS
2024 Trail hunter
that could be interesting to try and put a tender on it, never thought I would need to with the hybrid battery and 12v battery, but it might need to for longer than 3-4 days, I am pretty sure we could put a tender under the hood on the positive battery post there.
BoboForShort
Tyler
Something is wrong if it can't sit for more than a couple days. You have some sort of parasitic draw. Mine regularly sits for a week or more at a time in the airport parking lot.
I have heard of people using the app to remote start their truck every now and then if they're away for a month or more just to top up the battery and get some fuel moving through the lines.
