Aluminum Valve Stem Caps
JED
Southern Tier NY
2015 Tacoma TRD Sport
If you live in a climate that utilizes salt in the winter for road maintenance never put aluminum aftermarket caps on your valve stems.
Dissimilar metals and a corrosive. They are nylon for a reason
had to soak them in nuts off, heat them and utilize (2) vise grips to easy them off. Ugh !
2024 Tacoma Aluminum Valve Stem Caps IMG_7369
Chico
Arnaldo
2024 Toyota Tacoma
I was told a while ago by a tire technician at a large Tire Shop, never to use those metal caps, because they damage the stems.
JED
JED
Southern Tier NY
Caps came with the rims and I never gave it a second thought. As I get older these little mistakes seem to happen more frequently ☹
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Wow, hate to say it at my age. I have never come across this situation. Yeah, I will change my Immediately. Thank you for the tip. Makes sense.
Reactions: JED
PUMPKINKING
Ed
Vancouver, Canada
2024 TRD Off-Road Tacoma Solar Octane
I bought aluminum caps for my Subaru and they fused with the stem. I tried to get them off but damaged the stems and had to get them replaced at the tire shop. Never again LOL.
Reactions: JED
Sner
Never use them - ever. It’s why all new valve stems or valve stems on new cars use plastic caps - they won’t seize on. Imagine something as simple as wanting to check your tire pressure or put air in or take out air of a tire and you can’t get the cap off. Plastic caps have nothing to do with manufacturer being cheap, I've never understood the draw for metal valve caps.
Reactions: JED
