Lost 2nd, 4th and 6th gear @ 14,500 miles
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
Reverse, 1st, 3rd and 5th still engage.
When shifting, it will not go into the gate, it goes in partially and will not seat properly. I can still drive it using 1st to 3rd and to 5th.
Anybody else have these issues with their manual tranny?
I will have to wait until Monday to take it to a dealer for official diagnostics.
A few early manuals had a similar problem. If I remember it was a fairly simple fix? Someone will chime in with better details?
Sorry but it’s not a simple fix..
https://dot.report/bulletins/11007438
T-SB-0058-24 7/8/2024 Tacomas equipped with a RC60F manual transmission may exhibit a condition where the vehicle is unsable to shift into second, fourth, and/or sixth gear. Replace Transmission Assembly and Torque Converter
stuckinsocal
24 TRD OR 6MT
Sorry, that is a transmission swap; there is a TSB as the poster above suggested. May I ask what mileage you had before this happened and if there were warning signs (I own a 6MT in that VIN range as well).
Reactions: oxi
oxi
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
14,500 miles
stuckinsocal
24 TRD OR 6MT
14,500 miles
Thank you for the information, and I hope the warranty work goes smoothly and quickly for you. I thought that all of the failures would be within a few thousand miles, and as such it does worry me a bit to find one fail at over 10k miles. I'm thinking about that extended warranty right now....
(Silver lining with this issue is that at least it isn't a show stopper if it fails in the woods; you can limp back in 1st / 3rd / 5th back onto a road at the very least)
Reactions: oxi
oxi
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
June 5th will be my technical portion. About 4 manual transmissions available, 1 in Chicago and 3 in Pennsylvania.
Orders it on June 6, will be at dealer June 9. Total 5 workdays back on the road.
He is already getting the rental lined up for me.
stuckinsocal
24 TRD OR 6MT
It is a bummer but glad to hear they are taking care of you. Silver lining is that you'll have a new transmission after the process change, while the rest of us have to just wait and see if it will happen as I don't think there is a way to see if ours is cracked / going to crack.
Tacocho
Alex
Portland, OR
what does your VIN end with? Mine is around ~42000 and I’ve got around 11k miles no issues. Sorry to hear you’re dealing with this. Allegedly they fixed it past vin #s 25000+
Reactions: oxi
oxi
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
Mine is 13,744
oxi
oxi
Pete
Wisconsin
2024 TRD Sport 6MT
My truck has been dropped off at the dealer. It took him about a minute to verify the condition. They will order a new manual gearbox Friday.
Good news it is the same Master Tech that worked on my 05 X-Runner back in the day. He is the top rated (longest tenured and most trained) Master Tech in the Chicago Region.
He was looking forward to working on my truck because this dealer has not seen the manual gearbox Tacoma. In other words, I can rest knowing it will be done properly.
As a decent rental, I snagged a 25 Camry awd, though it is just an LE model. Very quick off the line and passing cars, faster than my Tacoma.
Andrace
2024 TRD Off-Road 6MT
With the TSB being specific to a production window I think it's (probably) rooted in a casting issue with the case for the transmission, and they updated production once the issue was identified. Did they say anything about the root cause?
I would expect that the replacement or those produced after the production window to not be subject to this particular issue.
I just hope mine falls within the warranty window and close to home, so the one known issue is remedied.
