Cleaning the engine bay on hybrid
zbennett
Zack
SC
2024 Tacoma TRD OR Hybrid
My engine bay is looking pretty dirty with pollen and dust. Im hesitant to spray it off with a hose due to hybrid components. Has anyone sprayed it off and been fine?
crepr12
NEast
2025 Limited Hybrid
Spray it...lmmfao...man I dont even like looking under the hood..First vehicle I ever felt that way about. Good luck OP
Mightyquinn
Andy
Fayetteville,NC
2025 TRD Pro Ice Cap/Cockpit Red
This is the first hybrid I have had but I am not hesitant to clean an engine bay. I've done it yearly on all my cars and have never had an issue with any of them. I will usually soak it down with Super Clean and let it soak and then spray everything off with a pressure washer that I use to wash the cars with so it's a low PSI one and electric. Just don't go in real tight around electrical connections and you should be fine. After everything is rinsed off I will take a leaf blower and dry it all off as best I can and then turn the car on to let the heat dry everything else up .
yoloborz
NJ
+1 to this. you'd think my hood was open all spring with the amount of pollen and dust that got in. basically took a microfiber cloth and maybe a wet rag and the whole thing looked great.
Wet rag, air compressor.
21K miles in all conditions. And this was maybe 20 minutes of work.
2024 Tacoma Cleaning the engine bay on hybrid IMG_8049
