Removing HUD bezel?
Chip
Toyota trailhunter
Id like to know if anyone removed the bezel of the HUD. I get a really bad glare from it and want to paint it a dark black or some other non reflective color.
Need to know if its just clipped in or if it requires something other than prying up on it to get it out. Pictures or a parts diagram would be much appreciated.
2024 Tacoma Removing HUD bezel? 1000022215
2024 Tacoma Removing HUD bezel? 1000022216
2024 Tacoma Removing HUD bezel? 1000022219
sylvestk
Kirk
SF Bay Area
Hi Chip, did ever you find out how to remove it? I want to do the same with a piece of dark flat black vinyl or something. Plus mine squeaks and I wanted see if I could fix that too
I assume it pulls up (maybe with the help of a trim tool) but would hate to pull the wrong direction and damage it or the dash.
sylvestk
Kirk
SF Bay Area
Thanks Baltimore. I was able to pop it out with just my hands.
I'm debating whether I should paint it a dark flat black, or find that type of thin felt they use inside of camera lens hoods. And use that on that large slope that send to get the sun glare.
2024 Tacoma Removing HUD bezel? PXL_20250625_214348270
2024 Tacoma Removing HUD bezel? PXL_20250626_004906785
2024 Tacoma Removing HUD bezel? PXL_20250625_214312843
sylvestk
Kirk
SF Bay Area
For reference (in case if a boo-boo), the part number for the instrument panel hole cover (also called a blank cover, dashboard panel cap, or instrument panel assembly) is:
55548-AK010.
Runs about 50 bucks.
1986Bronco
1996 Sambar, 2021 V90, 2023 Bronco Badlands, 2025 Tacoma
In my V90, this is the bane of my existence. The fabric like material gathers dust, lint, anything that is the exact opposite color from the air and does not let it go.
Canufixit
Canu
New England
2025 sr DC 4x
I always hate to change something and later regret it ... i.e. Peeling, cracking, fading paint - and have to remove it later or buy a new piece. Why not just wrap the area with a non reflective black/dull/flat tape and see if that works first. Easy to remove if needed ... JMO.
sylvestk
Kirk
SF Bay Area
I got the flocking material the other day and just installed it on the bezel. I ordered 60cm x 10cm.
It turned out great. It's very thin and easy to work with. It's super anti-reflective. But time will tell how it holds up in the sun.
I used some thin scraps to pad the bottom. Hopefully this will prevent the squeaking.
2024 Tacoma Removing HUD bezel? PXL_20250713_011023957
2024 Tacoma Removing HUD bezel? PXL_20250713_011040700
2024 Tacoma Removing HUD bezel? PXL_20250713_012108387
2024 Tacoma Removing HUD bezel? PXL_20250713_012113020.MP
2024 Tacoma Removing HUD bezel? PXL_20250713_012435112.MP
Nvideon
Boynton Beach FL
Ever thought about one of those dash mats? They now have one available for the ones with HUDs
