hagglethorn
Russellville, AR
2019 4Runner, 2004 Yamaha FZ1, 2022 Kawasaki Versys SE LT+
I came from a Bronco to a Tacoma. Hood shake on these is minuscule comparatively. :LOL: I did notice it though… This seems like an easy fix so I’ll put a few more miles on and see if it bugs me.
Yeah, people are freaking out about the hood shake, and compared to some other vehicles I have driven it is really not all that bad.
Maybe it is worse on some trucks than others, but I hardly notice it myself.
Nvideon
Boynton Beach FL
So I got to solve the hood vibration with the help of a member ordered this and installed it no more vibrating hood.
Here is what it looks like installed, got it from Amazon.
Automotive Door Weather Stripping 10Ft Car Door Rubber Edge Trim Seal Strip Gasket with Top Bulb Easy to Install for Car Bus Camper Boat RV Truck Doors and Home Applications
Yooo thanks for this! A+++
I see a lot of people doing this, but no much on the results. Does it eliminate the hood shake?
Yes I can tell you with a positive results the shaking is gone. That was the point of the post.
Thanks. I knew that was the point of the post but most people talked about how they were using the weather seal but not much about it stopping the shake.
Iqudayo
Iqudayo
2024 Toyota Tacoma
Understood definitely work the time, and effort
Viper_00
Walter
VA
Just ordered. Looking forward to giving this a try
Halifax, NS
2025 TRD Pro
I'd say about a 75-80% improvement over no seal, I may extend the drivers side and see if that helps more, it shakes a bit still but you REALLY gotta be focusing on it to the point it would be unsafe to be driving
Halifax, NS
2025 TRD Pro
I’ll edit my other post with the length of the new drivers side piece I put on, something to note, if you don’t grab and pull the exposed metal rib out it’ll leak rust down into the drain below which could cause future ugly issues, but I went from an 8 1/4” piece to a 13 1/2” piece it looks a bit better
2024 Tacoma Hood Vibrating Fix! (Weather Stripping / Rubber Trim Seal) IMG_6903
james cole
Bronco
I have a Bronco V6, ZERO hood shake.
