TRD Cast Aluminum Running Boards - Anyone Installed Themselves?
Quinn
Qiunn
2024 Tacoma iForce Max TRD OR
I just received mine for a planned at home install, and all the mounting brackets are angled back. Of course the installation instructions are worthless and do not mention anything about re-alignment, so curious if anyone else encountered this. The bracket holes all appear straight/90 degree so I'm assuming these will need some sort of correction.
2024 Tacoma TRD Cast Aluminum Running Boards - Anyone Installed Themselves? IMG_0150
2024 Tacoma TRD Cast Aluminum Running Boards - Anyone Installed Themselves? Screenshot 2025-08-11 at 9.28.05 PM
Tac931
Tim
NJ
TOYOTA
I didn't have to make any adjustments. Take off the 4 bolts under truck , then the boards go on
Quinn
Qiunn
Do you recall the brackets on your set being angled as well?
Tac931
Tim
NJ
TOYOTA
I'm not sure they can adjust. If the holes won't line up then there may be a problem. 15 minutes install for each side
Have you tried having someone hold them in place (or loosely bolted them in) to see if they look square?
I honestly can't remember what my brackets looked like, but I just put them on and they lined up fine. You may be overthinking it.
sabinjo
NJ
2024 Tacoma TRD Sport Premium
I had the same exact issue with mine, all of the brackets were off and a bunch of the bolt holes didn’t line up. After thinking something was wrong and that I’d have to send these damn things back, I realized I was overthinking it way too hard.
Simply loosen bolts holding the bracket to the board itself a little so they can move, then thread all the bolts into the pre-threaded holes underneath the truck, realign the brackets and tighten them once the running board is loosely bolted underneath and then tighten everything up.
It’s really that simple.
Ray T
Ray
24 tacoma pro
Don’t remember mine being angled but I could be mistaken
Quinn
Qiunn
yep, exactly. Mounted them tonight. They look fine. Just the way they are made to accommodate the shape of the truck it seems. It’s wild though because the predator tube step I removed has brackets they are totally straight. ĀÆ\_(惄)_/ĀÆ
2024 Tacoma TRD Cast Aluminum Running Boards - Anyone Installed Themselves? IMG_0152
sabinjo
NJ
Looks great! My truck didn’t come with anything so I didn’t have something to remove and compare with.
