Regius
Reg
New York
2024 Tacoma TRD Offroad, non-hybrid, 5.5 bed, silver
Just put on the AWE 0FG (@Sara/AWE), 99% smooth process but the sharp elbow of the system toward the spare tire area does touch the spare tire bracket. It just rests next to it. There is going to some hitting if I go over bumps but so far I don’t hear it transmitting into the cabin.
2024 Tacoma AWE 0FG Cat-Back Exhaust Fitment on 2024 Tacoma TRD Offroad IMG_3396
2024 Tacoma AWE 0FG Cat-Back Exhaust Fitment on 2024 Tacoma TRD Offroad IMG_3403
2024 Tacoma AWE 0FG Cat-Back Exhaust Fitment on 2024 Tacoma TRD Offroad IMG_3405
2024 Tacoma AWE 0FG Cat-Back Exhaust Fitment on 2024 Tacoma TRD Offroad IMG_3401
Viper_00
Walter
VA
Contact awe and send them some pics. I’m sure they will help you out
Regius
Reg
New York
I wish the tips were welded to the pipes. Those clamps or claps look horrible.
Let’s hope the tips don’t fall off.
Sara/AWE
Sara
Horsham PA
Hey OP, those tips are not positioned correctly, they should both be rotated 90 degrees so the logos are facing up and the slash is pointing backwards. From there you can rotate the clamps to the top of the tips so they are not visible. If they are properly tightened down there should be no issues with shifting, etc.
2024 Tacoma AWE 0FG Cat-Back Exhaust Fitment on 2024 Tacoma TRD Offroad 3015-33254_4_d58aff7e-cc98-4ec3-87a0-73d7a18050f
The pipe positioning is too close to the bracket, ensuring that all of the pipes especially those upstream are fully bottomed out will give you more clearance on that particular bracket. Be extra careful with G34 to G33, given the angle of the piping it is prone to backing out.
Tacoma Installation Instructions
If you are still unable to adjust it away from the bracket, please reach out to our customer support team before you do anything else and they can assist you in getting your system adjusted properly.
Of course we are here on the forums, so if you need any extra support I am just a PM away! :handshake:
Kielly
2024 Tacoma Sport+ 6M
Just pulled the plug on one myself. Went with the axle dump version. Cheaper, and will benefit when off-road.
Those tips are a huge improvement to the OEM massive ugly tip lol.
I'll try and get some sound clips when I get it installed. Lot's going around online of the automatic but nothing really showcasing the manual.
Taco Ji
New Jersey
2025 Toyota Tacoma
Let us know if there is any drone at highway speeds. Good luck.
Sara/AWE
Sara
Horsham PA
BashGuard is a great option and plenty of clearance for obstacles on the trails :fistbump:
Feel free to post up those sound clips when you get them!
Regius
Reg
New York
Sara, I am sure each section is pushed into the previous tube to the furthest, but I’ll check, my concern with this approach is that the G33 elbow that’s designed to “climb” up and down the rear differential will then be moved forward. It is already not exactly above the differential. I am going to try to twisting method. Based on the Motoroso installation video, there was a very quick shot that shows his G33-G34 is very far from the spare tire piece. By the way I can’t find your own install video anymore? :)
Regius
Reg
New York
How loud are they?
Very pleasant. It is obviate not a rumbling /gurgling sound but more of a continuous fart, but I can live with it. No noise when not giving more than 2.5RPM gas
Kielly
Side note for any Canadian peeps that may order the AWE, Avoid TDOT Performance. They don't actually carry it in stock, so your 7 day shipping turns into 20-23 days lmao
