Popping sound beneath rear of truck bed?
james cole
Bronco
Easy fix! Stuff some rubber spacers under the truck where the bed sits in the rearmost part of the frame (thats where it pops)
popping fixed.
Tacoyaki
Tacoma TRD Off-Road
Can you link to the spacers you use and a pic of where you placed them?
Reptar
Michigan
2025 Tacoma TRD OR LB
Toyota replaced my entire bed. It was apparently a known problem that Toyota, not the dealership, acknowledged.
BAQ717
‘24 Tacoma TRD OR
Oof. Yeah I’ll deal with the occasional popping sound lol.
Suzay
Hawaii
2024 Tacoma sport
I have the same noise on a 6ft bed. I crawled underneath and noticed, it looks like the bed just has a locating tab sticking through rear cross rail in that spot and possibly does not have a fastener or at least never has had a fastener. I'll mention it to the dealer during my first service
Any update on this?
Suzay
Hawaii
2024 Tacoma sport
popping fixed.
Could you take a pic of where you put the rubber spacers
Suzay
Hawaii
2024 Tacoma sport
I’ll try to put rubber spacers and see if this solves my issue. Tho I’m not stepping on it for the noise to occur. It’s just when truck bed is cool and first right turn. If the spacers don’t do it I’m thinking bed stiffeners.
james cole
Bronco
At the moment I can't but its super simple:
1. Find exactly where your bed pops, could be anywhere near the edge of the bed closest to the tailgate and identify the spot.
2. Get under the truck at the edge where the spare sits closer to the tailgate area, you will see the composite channeled form of the bed underneath, identify the location where it pops and put a rubber washer in there, sandwiched between the frame and the bed composite, you may need the help of a flat screwdriver so that you can wedge it and lift the bed for a bit more space to instert the washer in.
3. Walk again in the bed's edge because the pop may have shifted, if it did repeat step 2 if not youre done get a nice ultra cold beer for me.
This also quieted my bed under certain bumps.
whoacz
Adam
virginia
Taco Soon
Curious if anyone else has had dealer address or found alternate fix to placing spacers between bed and frame?
My 2025 has exact same issue.
