OEM Steelies - Not exactly black
slater
san diego
2024 tacoma sr5/2wd, white
What did you end up doing for the center caps, think it looks better as is vs the stock SR center caps....
Winkydee
Winkydee
Pete
Niagara Region, Ontario, Canada
2021 Bronco Badlands (2dr manual), 2025 Tacoma TRD Offroad (6spd manual)
Not knocking it, just seems like a lateral move to me...
I know its a thing, guess I dont have the balls to do it....
Could have had your offroad wheels power coated all black for $300....
I really like the sr5 stock wheels & had a sr5 before it was bought back due to paint defects.
I really wanted to blackout the sr5 wheels....
Well second truck I went with a sport even though im not a fan of the hood at all....
Hated the wheels.....
So when I got the sport, I had the wheels powder coated..
But then I sold them, when I came to the conclusion that tire options suck when it comes to 18's & your stuck with E load which ride like crap on these trucks, stiff sidewall...
Looks good.
I'm running steelies in the summer, gonna use up the Trail Terrains. In the winter, I'll be running the OEM alloys (powdercoated satin black) with 255/80r17 E Loads. I know the ride will be a bit firmer but I find the Offroad suspension pretty soft so it should balance out, I'm hoping anyway.
slater
san diego
Looks good.
Got it, that makes sense...
As I stated I ended up selling that wheel & tire package.
Made the truck look like a skateboard to me....
These trucks need a bigger tire..
Winkydee
Winkydee
Pete
I hear ya'.
I love the look of bigger wheels too. I'm looking forward to my pizzacutters for winter, and may like them enough to keep them on all year round.
There's just something about steelies for me. I wish our winters weren't so crappy so I could run steelies all year round w/ bigger tires.
izzy
Bay Area
They're the OEMs and are +25. They are only 7inch wide so you won't be able to run 285s, but the factory 265s are a nice fit, not much more poke. I think they look amazing, especially with that gunmetal finish. I was expecting your typical gloss black, glad to have this surprise when they showed up!
42601-AK031
Do you have a part number for the lug nuts? They're different than the flat seat style for the aluminum wheels. For the steel wheels they're acorn style.
Thank you!!
2024 Tacoma OEM Steelies - Not exactly black Screenshot_2025-08-30-17-43-42-382_com.android.chrom
2024 Tacoma OEM Steelies - Not exactly black Screenshot_2025-08-30-17-43-51-885_com.android.chrom
Getting conflicting data here from Toyota parts websites lol but I'm pretty sure this is the acorn lug nut the steel wheels will need
StreeTaco
2024 Tacoma TrailHunter
The factory alloy nuts work just fine
izzy
Bay Area
I wouldn't do that to be honest. The acorn alloy lug nuts have a flat bottom and the ones for the steelies have the tapered bottom, which the steel wheels need.
StreeTaco
The alloy lugs are tapered as well.
potato5
Matt
new Hampshire
25 Tacoma sr5
Thank you!!
I'm running the Toyota steelies, I use these if you're interested. They have a 60 degree Conical Seat.
24 Gorilla Black Lug Nuts 14mm x 1.50 Bulge Acorn Seat 3/4" Hex 14x1.5
41148BC
longforadv
2024 Tacoma sport plus
In Canada these were $117 each.
They're the same as the spare rim, 17 x 7, 95.1 bore, +25 offset
I’m looking at the steelies as well, $470 Canadian for the set and $480 in lug nuts to hold them on.
Any suggestions on a good set of nuts that don’t cost more than the wheels? ( and are able to handle 154 ft lbs torque )
Cariboo Ryan
Quesnel, British Columbia
2020 GMC Sierra AT4
My Toyota dealer in BC quoted me $3.50 each for lug nuts that work with the OEM steelies.
izzy
Bay Area
I ended up with the TRD M14x1.5 lug nut set:
2024 Tacoma OEM Steelies - Not exactly black 1765236671731-
But yeah any acorn style lug nuts will work
Mcgard makes the TRD set above and they're actually really nice quality
They sell these:
https://shop.mcgard.com/products/au...-m14-x-1-5-thread-size-set-of-4-lug-nuts-1204
Which would be fine for the steelies, might cost more than what Toyota is offering but they will for sure look better longer.
Ironically Mcgard on their own product page says to not use the TRD style lug nuts on steel wheels... TRD packaging doesn't say anything about that. My independent mechanic said it was fine and Toyota dealer didn't complain. They torqued them to 154ft lb despite me saying 120 is probably fine lol
longforadv
Did you torque these to 154 like the manual says, everyone I speak to says it's too high, the tire place, and I could only get a hold of one Toyota service dept to answer me and they said it's 90lbs. Even Google ai says it's too high. Only chat gpt agrees with the manual
The more I went back and forth with chat gpt, yes the manual definitely says 154 for steel wheels, and gpt clarified it's because the hub assembly is basically the same as the tundra now, with larger studs then they used to have in previous gens, and the tundra has had those torque specs for steelies going back to their 2nd Gen. And now with the 3rd gen tundra it's pretty much identical to the Tacomas 4th. So I guess I'm sticking with the manual and hope they don't snap.
I had my doubts about those torque specs too. Google AI claiming the 154 ft lbs in the manual is likely a misprint. But the dealer reassured me that the manual is correct . So when I get Costco to install my winters, I better get them to change the 97 ft lbs on the work order to 154 so I don’t lose my wheels
izzy
Bay Area
I drove around for a while at 120ft lb
I don't think they're gonna fall off at 100 either to be fair lol
potato5
Matt
new Hampshire
25 Tacoma sr5
The same tire place when I just changed to my winter tires finally admitted that it was 154, I guess they just didn't have enough 4th gen Tacomas with steel wheels at the time to consider it.
