- First Name
- Tony
- Joined
- May 18, 2024
- Threads
- 15
- Messages
- 1,345
- Reaction score
- 1,381
- Location
- Salmon Idaho
- Vehicle(s)
- 2024 Tacoma OR with Premium package
These trucks are so capable at stock ride height.
But what about the malls?You really don't need to lift them...
I somewhat agree but the biggest thing an independent front system needs is flex. If you own a solid sway bar then find a way to disconnect it as that improves flex a ton more. I am springing for a 6MT TRD OR with the 4.30 gears and have invented a cable operated disconnect because the idiots at Toyota Canada didnât realise they should have copied the same options available as USA where they offer the sway bar disconnect.I've had an 87, 19, 22 and now a 23 Tacoma. LIFT IT if you think it's a better looking truck. I only go to borrego once a month, I don't need 6" but it looks great and drive great. Who cares there parts will wear faster or that I get 12.9 a gallon. If you can't afford it, don't buy it. LIFT IT!! (make sure you go somewhere who knows what they're doing)
