+25 vs. +35 Offset - looking for opinions, feedback, thoughts
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
2025 Toyota Tacoma TDR Pro
New TRD Pro owner coming in with his first post. Truck lands at the dealership in a few days and I'm gearing up to start working on it ASAP.
I'm coming off of a converted Sprinter that I built up and just sold it yesterday.
There are a lot of opinions on offset and I'd love to get a thread going to help me decide on what offset makes sense for what Im building. I don't mind a little tire.
Truck is a 2025 TRD Pro - Mudbath.
Wheels will be Method. Either 703s with a +35 offset or 305s with a + 25 offset.
Tires are most likely going to be 315/70/17 Falken Wildpeak AT4W
I do not plan on doing any suspension work right away. From what I've read, I can put that tire on a stock TRO Pro and it won't rub.
OEM pro is +20, I’d say +25 to 0. FYI +35 would tuck in the wheel well an additional 1.5 CM, this may rub or be very close to the UCA with a 315/70/17
Compherh
Sam
Miami
2025 tacoma limited hybrid
I have +25 on 18x9 fuel rebel wheels. Sticks out of fender half an inch in the front.
gofastdan
I have exactly the same set up as ixo and am very happy with it but you're looking at very wide tires. The +25 might be a better option for you, especially considering that I believe the Pro has a bit wider fenders than the TRD OR.
2024 Tacoma +25 vs. +35 Offset - looking for opinions, feedback, thoughts PXL_20250503_182637514
2024 Tacoma +25 vs. +35 Offset - looking for opinions, feedback, thoughts PXL_20250522_014118616
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
I believe you are correct on the wider fenders, hence the wider tire to fill the gap. The +25 is my preferred wheel choice but they’re both great looking wheels. Love your set up as well. Very functional.
zekesview
zekesview
Zeke
Walnut Creek, Ca
www.zekesview.com
Pulled the trigger. Method 305 17x8.8 +25 offset.
Ironically, Method was out of stock but I found them on Amazon, cheaper and they arrive Thursday. Plus I had a bunch of Amazon credit points from their credit card that I applied all towards this purchase. "honey, the rims only cost $500..." #guymath
xxJDxx
BC, Canada
2016 4Runner
Looks great. Is that stock height?
gofastdan
I have the Wescott spacer on the front end and Dobinson 819's on the back to accommodate the weight. As it sits the front is ~1 1/4" higher and the back is ~1/2" higher than stock.
