Side Molle Panels for 2025 TDR OR - 6FT Bed with OEM Tri-fold Tonneau Cover
meltswithmilk
Alex
canada
2025 TRD OR
Hi guys, i've been having issues finding compatible molle panels for my 4th gen TRD OR with 6ft bed. I had ordered the OEM ones but i was told that they are not compatible with my OEM tri-fold hard cover due to the placement of the rails after installation. The other alternatives i was looking into like rough country are only available for the 5ft bed. Did anyone find suitable alternatives? Thanks in advance!
theDLR
AL
Nevada
2025 TRD Sport
i been looking for something for 6ft beds also, so far, can't seem to find any either
mtbocoee
Ocoee, TN
2025 Tacoma Trailhunter, 2000 Tundra, 2013 Highlander
I installed the OEM front and side Molle panels on my 2025 6' bed Trailhunter before adding and Alu-Cab canopy top. They utilize the screws in the bed rails for installation and slide underneath so I'm not sure why they would interfere with your tri-fold. Each panel also requires you to drill one hole for rivet nut installation. Check out the YouTube by Smoky MTN Taco for an installation demonstration. If the Tri-fold utilizes the rails for installation you may have to remove it to install the Molles.
mattlee
Matthew
Washington staye
2025 Trailhunter
I installed the OEM panels and a Retrax Pro without issues. I don’t know how the factory mounts tri-fold mounts though.
2024 Tacoma Side Molle Panels for 2025 TDR OR - 6FT Bed with OEM Tri-fold Tonneau Cover IMG_4990
2024 Tacoma Side Molle Panels for 2025 TDR OR - 6FT Bed with OEM Tri-fold Tonneau Cover IMG_4985
meltswithmilk
Alex
canada
2025 TRD OR
The reason the dealership gave me was that when you install the OEM tri-fold the rail's get moved down and in about 3/4" so i guess the panels just dont fit. I appreciate the response and the video!
meltswithmilk
Alex
canada
2025 TRD OR
That is one nice setup! Yeah wish i had known about this prior to purchasing the OEM hard cover. Would've gone with something similar to this. Cheers for the reply!
Rubenc87
Ruben
2025 TRD PRO
Do you have a pic of the front corners of the bed where the canister meets up with the Molle Panels? Thanks
mattlee
Matthew
Washington staye
2025 Trailhunter
I’ve been sick with Covid or I would’ve got you some pictures. Now I need the rain to let up.
Rubenc87
Ruben
2025 TRD PRO
No worries. I have the same bed cover as you and was considering the Molle Panels for mine.
Rubenc87
Ruben
2025 TRD PRO
So the Molle tucks behind the canister (to the sides) I wasn't sure if the canister would interfere with the Molle or not. I would somewhat have to remove and re install the cover to access the corner portion of the Molle or can I just slide it between the bedside and canister? Thanks
mattlee
Matthew
Washington staye
2025 Trailhunter
I think you’d have to remove it. I installed the molle panels myself but had the cover installed. The panels install behind the bed rails and are pretty much flush with them. You use some of the bed rail screws for the installation. You’ll also have to drill a couple of holes in the bed.
Rubenc87
Ruben
2025 TRD PRO
Thanks for the info. I want to do this but I don't want to do this. LOL. I installed the cover myself. That's why I'm debating
