jmspradlin
Jason
Izzy7108!
24 TRD OR
Swapped out the massive eyesore of a tailpipe with the OEM/TRD turndown. Easy 15 minute job - 2 15mm nuts, 2 hangers, pull the old off, and install the new. I did lower my spare to the ground to make removing the old pipe easier.
The TRD turndown isn’t as pretty as the SXTH but it’s cheaper, in stock, and OEM quality.
2024 Tacoma TRD off-road exhaust tip / turndown installed IMG_0425
2024 Tacoma TRD off-road exhaust tip / turndown installed IMG_0428
2024 Tacoma TRD off-road exhaust tip / turndown installed IMG_0427
2024 Tacoma TRD off-road exhaust tip / turndown installed IMG_0424
Bucky_O
Seattle
2025 Tacoma TRD OR Hybrid
This was probably one of the most gratifying mods I’ve done so far. Had no idea there was an OEM off-road pipe option. I’ve become a NYTOP junky for add-ons. Nice work!
SauteArabia
Greg
NJ
2024 Toyota Tacoma
Slight noise difference, but saves you 15 pounds.
gonzotaco
Adrian
2024 Tacoma TRD Off Road
Do you notice any change in exhaust smell since it is closer to the cabin?
shuo
shu
Seattle
2026 TRD Off-road Bronze Oxide
I ordered the lexland trail pipe but its delayed. I decided to just cut the tail pipe for now. I might even paint it black.
2024 Tacoma TRD off-road exhaust tip / turndown installed IMG_4435
2024 Tacoma TRD off-road exhaust tip / turndown installed IMG_4437
BR0D1E
Brodie
Portland, OR
2024 Tacoma Hybrid OR
i got one of these almost as soon as i got my truck. if there is extra noise, it's completely overshadowed by road noise and/or music playing. it's essentially negligible. what it does do is remove that eye-sore of an exhaust pipe and save a trivial amount of weight.
Where I'm stuck between is: I quickly switched to the OEM trail dump to get rid of the huge tailpipe. And generally no complaints. As mentioned, I feel like it's a touch louder but on the road I don't even notice or hear it... EXCEPT that at about 950-960rpm it triggers an awful drone that actually hurts the head. If you have ANC active, it doubles the effect making it cringe worthy. I keep wondering if adding the resonator back would negate this "sweet spot" of acoustic annoyance.
Otherwise, the LTD is incredibly quite to drive
shuo
shu
Seattle
I am experiencing the same thing. Planning to disable the ANC today. Will report back.
