Baja 686 Mirror Ditch Light Harness
dvrgz
Los Angeles
mtc
24 Toyota Tacoma TRD OR
Plug and play? Will the backlights on the DDs work?
dvrgz
dvrgz
Los Angeles
Not quite. But it wasn’t that bad.
- Remove Panels
- Drill two holes into each mirror (using the template provided with the harness).
- Secure mount using hardware provided
- Run each light to your power source (I’m using an 8 Panel Switch Panel)
I’m using Baja Lights. I’m not familiar with DD’s product line. There’s a few people on IG running DD’s with the harness. Looks awesome.
Toy-truck
Houston, TX
When the side mirrors are folded in, do the light touch the paint on the body of the truck?
ThatBronze4G
Lloyd
United States
2025 Toyota Tacoma TRD OR
i have a set of the DD brackets sitting on my desk. just waiting on them to release their fog light kit that replaces the current SS6's and i will snag the SS2's for these brackets as well.
larkhen
New Mexico
Accord
can you show a copy of the install instructions? I'm curious how the wires are routed to the engine bay.
dvrgz
dvrgz
Los Angeles
The instructions don’t get that in-depth. I attached the last page of the install instructions. I’ve seen it done a few different ways on instagram. I ran it through a crevice in the door jam and the engine hood. See attached.
2024 Tacoma Baja 686 Mirror Ditch Light Harness IMG_7786
2024 Tacoma Baja 686 Mirror Ditch Light Harness IMG_7791
lokee99
ken
CA
24 Tacoma ORP
Curious about the wire location. Have you had any issues with the wire getting damaged routing that way? Also do you have q pic of where the wire comes out from the door? Looks like it comes out of the upper hole.
