Heater output very disappointing. Warm not hot. Update in last post
Satisfied with heater on your Tacoma
  • Total voters
    64
TheGreatWhiteNorth
Alaska
2024 SR5
Im feeling this righ now. Mine is mediocre as well. I live in Interior Alaska, and its been -25 the last few days. All my previous Tacomas has horrible fan output, but this one is significantly worse. It gets hot enough, but the blower has a super low output on full blast. The cabin filter is clean.
What irks me about this 2024 vehicle is you cant have the defroster, face, and floor heat on at the same time. Thats huge when its -30°f. If i blow the air on my face and feet...the window starts to freeze. If i blow the defroster and feet only option, my upper body is freezing.
My third gen tacoma had very mediocre blower speeds, and only gave me 2 of the 3 options as well. MANY new vehicles ive seen offer that. Ive been in many work trucks with super heaters. If we can put rovers on mars....im sure engineers can make a tacoma that blows full speed with all three blend doors open.
SR5 spec. Manual heater and fan. The truck takes a long time to get up the cabin up to temperature. Floor setting, floor and defrost setting both take a long time to get the cabin warm. Up to 10 minutes. Heat output is warm, never hot. Heater output increases after I get off the freeway and back to surface streets. I have been driving for 30+ years and have never had this crummy heater.
Drove my other 2 vehicles in the personal fleet during the same cold spell last week. 2006 Scion Xa, 3-5 minutes car is up to temp, heater output is HOT.
Drove Honda Odyssey with auto temp controller. Plenty of HOT air to heat the massive cabin.
Is that just the nature of the beast of the Tacoma 4th gen to have a limp heating system? Have not researched, maybe an overly smart engine thermostat electronically controlled.
Strange, Montana resident here and the heater is never on high for long! Even at -40! Also I’m definitely sensitive to being cold after 2 bouts with cancer 🥶 You drive in eco mode? Not sure but that could be part of the problem? If not maybe a bad mixing valve?
BlancoTaco
BlancoTaco
Caleb
2024 Tacoma SR5
Took it into the dealer for the Toyota care oil change. Asked them to look at the heater, gave them a paragraph of issues with the heater as stated in this post. Service writer puts on work order. "Customer states heater does not get hot. " Technicians sign off. "Checked heater output. Output 100F, meets manufactures specs." I had been running with settings of floor, or floor and defrost. When I got in they had floor and dash selected. To there credit it does get hot in the truck when set that way.
Drove into work today, 10F temperature, 5 minute preheat, 18 minute drive into work. Heater at max heat, max fan speed the whole way. Cabin never got hot. Same job, same route for 20 plus years, all kinds of weather. Multiple different vehicles on this route over the years. I have never had a vehicle where I could run the heater at max output on my drive to work and not be hot.
BlancoTaco
BlancoTaco
Caleb
2024 Tacoma SR5
Part 2.
I am an aircraft mechanic by trade. I tend to go down rabbit holes looking for the root cause.
Random trouble shooting thoughts.
  • When I got the truck I put speakers in the doors, I also installed some amazon dyna mat. I am wondering if when putting that in I disturbed the factory door sealing. They use a thick plastic door covering held in place with the sticky stuff.
  • Truck not having a tight cabin allowing air leakage?
  • Some obstruction not producing full airflow in the system
  • Clogged cabin air filter
  • the climate airflow doors are not moving to the correct location.
StreeTaco
2024 Tacoma TrailHunter
Mine is the same. AC thru vents blows hard. Heat is very low. I have the dual climate controls.. I’ve tricked it to blow heat thru the vents with high velocity by adjusting the passenger side temp lower than the drivers side. Sumting Wong
Yotota
Zane
SW WA
24 TRD
Defrost alone or defrost/floor automatically runs the AC compressor on our trucks (and all Toyotas that I've had) to dry the air. Floor and dash do not.
It sounds like your blend door in the HVAC box isn't working, allowing all the air to pass through the AC evaporator core and get cold. I see a few servos on the side of the HVAC box (Toyota calls it the "Cooler Unit") to control the air flow, and likely the blend door.
Have you done any work under or near the dash? Carpet pulled up? Center console? The wiring to one of the servos may have been damaged or disconnected. Or perhaps the servo itself isn't working.
My truck, on defrost or defrost/floor, can still get way hotter than comfortable. Something is up with your truck.
Tacohunter2024
Upstate New York
'24 Off-Road Premium Black
? Man. Sounds like youre unhappy in life and its Not the truck. Shouldve never responded man. I love life. Love the Truck. Its a gem. Take care.
TheGreatWhiteNorth
Alaska
2024 SR5
Sounds like youre a fag. People are discussing problems under "issues, repairs, warranties" thread. Naturally they are going to be of this nature. 😘
you say you "love life", then you try to stir up an Internet fight with a random stranger. You "sound" like a loser. Probably one of those medicated bipolars who are on the upswing. Love you
Tacohunter2024
Upstate New York
you say you "love life", then you try to stir up an Internet fight. You "sound" like a loser.
Haha, I copied and pasted your comment on one of my posts. 😂 That's glorious, so you not only proved how much an ignorant, hypocritical, d-bag you are; you called yourself a fag. :clap: Thank you, that was a good laugh to start the day.
TheGreatWhiteNorth
Alaska
2024 SR5
Thought you loved life? youre losing it. Oh boy.. .
Oh my! copy and paste! The psychological reason you're doing that is so you don't feel alone in this world and youre trying to find other like-minded Internet losers to agree with you. Classic psychology 101
But, by the nature of your first post, i already knew you were like that. I dont want to ruin the persons thread, so i'll ignore from here on out. Have fun pumpkin!
PNWkip
2025 DCLB SR5
SR5 in WA here. Temps between 30-45 F recently. Takes a while to heat up, but is hot AF after it does. I regularly have to turn it at least halfway down after driving for 15+ min.
Tacohunter2024
Upstate New York
Thought you loved life? Now youre losing it. Oh boy.. Look at you.
But, by the nature of your first post, i already knew you were like that. I do t want to ruin the persons thread, so i'll ignore from here on out. Have fun pumpkin!
Buddy, there's nothing you can say. I made a fool out of you. You apparently spend half your life on here running your mouth, I'm sorry if I ruined that, and in turn, most of your identity for you. Sometimes it's just better to admit you've been owned and keep your mouth shut.
TRD6MT
Christian
CT
25 TRD Off-Road 6MT Celestial Silver
My heat is atrocious. Its been like this since I got it, thought it was just the truck. 30 Deg or less everyday the last week, driving it all the time as its my work truck - I've tried the following things and regardless of what I do, it doesn't blow hot air until the truck is driving 15-20 min
1 - Let the truck warm up in the driveway (heat on) 10-15 minutes before driving - No heat at all, blows cold air at me while its 15* outside until driving for close to 20min
2 - Start the truck let it warm up (heat off) 10-15 minutes, then try the heat - Nope, same issue as before, ice cold
3 - Start and drive the truck heat on right away - same issue. ice cold air for even longer this time
I've tried every different fan position, high heat, 70*, 75*, nothing. Something is wrong here. Toyota dealer looks at the truck and says nope no issue. Meanwhile, while I'm freezing my balls off driving to work at 5am when its 5 degrees outside I got a truck blasting ice cold air at me.
TRD6MT
Christian
CT
Meanwhile my 339,000 mile 02 Prerunner, that spent most of its life in AZ , has heat that could sweat you to death regardless of how cold it is outside lol. Love my truck not gonna sell it but the dealers are useless. Hoping a DIY solution comes about
BlancoTaco
BlancoTaco
Caleb
2024 Tacoma SR5
So a small percentage of us have inadequate heater output. One of us needs to figure this out since the dealership doesn’t care.
