Heater output very disappointing. Warm not hot. Update in last post
Satisfied with heater on your Tacoma
  • Total voters
    65
TheGreatWhiteNorth
Alaska
2024 SR5
Im feeling this righ now. Mine is mediocre as well. I live in Interior Alaska, and its been -25 the last few days. All my previous Tacomas has horrible fan output, but this one is significantly worse. It gets hot enough, but the blower has a super low output on full blast. The cabin filter is clean.
What irks me about this 2024 vehicle is you cant have the defroster, face, and floor heat on at the same time. Thats huge when its -30°f. If i blow the air on my face and feet...the window starts to freeze. If i blow the defroster and feet only option, my upper body is freezing.
My third gen tacoma had very mediocre blower speeds, and only gave me 2 of the 3 options as well. MANY new vehicles ive seen offer that. Ive been in many work trucks with super heaters. If we can put rovers on mars....im sure engineers can make a tacoma that blows full speed with all three blend doors open.
SR5 spec. Manual heater and fan. The truck takes a long time to get up the cabin up to temperature. Floor setting, floor and defrost setting both take a long time to get the cabin warm. Up to 10 minutes. Heat output is warm, never hot. Heater output increases after I get off the freeway and back to surface streets. I have been driving for 30+ years and have never had this crummy heater.
Drove my other 2 vehicles in the personal fleet during the same cold spell last week. 2006 Scion Xa, 3-5 minutes car is up to temp, heater output is HOT.
Drove Honda Odyssey with auto temp controller. Plenty of HOT air to heat the massive cabin.
Is that just the nature of the beast of the Tacoma 4th gen to have a limp heating system? Have not researched, maybe an overly smart engine thermostat electronically controlled.
Strange, Montana resident here and the heater is never on high for long! Even at -40! Also I’m definitely sensitive to being cold after 2 bouts with cancer 🥶 You drive in eco mode? Not sure but that could be part of the problem? If not maybe a bad mixing valve?
BlancoTaco
BlancoTaco
Caleb
2024 Tacoma SR5
Took it into the dealer for the Toyota care oil change. Asked them to look at the heater, gave them a paragraph of issues with the heater as stated in this post. Service writer puts on work order. "Customer states heater does not get hot. " Technicians sign off. "Checked heater output. Output 100F, meets manufactures specs." I had been running with settings of floor, or floor and defrost. When I got in they had floor and dash selected. To there credit it does get hot in the truck when set that way.
Drove into work today, 10F temperature, 5 minute preheat, 18 minute drive into work. Heater at max heat, max fan speed the whole way. Cabin never got hot. Same job, same route for 20 plus years, all kinds of weather. Multiple different vehicles on this route over the years. I have never had a vehicle where I could run the heater at max output on my drive to work and not be hot.
BlancoTaco
BlancoTaco
Caleb
2024 Tacoma SR5
Part 2.
I am an aircraft mechanic by trade. I tend to go down rabbit holes looking for the root cause.
Random trouble shooting thoughts.
  • When I got the truck I put speakers in the doors, I also installed some amazon dyna mat. I am wondering if when putting that in I disturbed the factory door sealing. They use a thick plastic door covering held in place with the sticky stuff.
  • Truck not having a tight cabin allowing air leakage?
  • Some obstruction not producing full airflow in the system
  • Clogged cabin air filter
  • the climate airflow doors are not moving to the correct location.
StreeTaco
TN
2024 Tacoma TrailHunter
Mine is the same. AC thru vents blows hard. Heat is very low. I have the dual climate controls.. I’ve tricked it to blow heat thru the vents with high velocity by adjusting the passenger side temp lower than the drivers side. Sumting Wong
Yotota
SW WA
24 TRD
Defrost alone or defrost/floor automatically runs the AC compressor on our trucks (and all Toyotas that I've had) to dry the air. Floor and dash do not.
It sounds like your blend door in the HVAC box isn't working, allowing all the air to pass through the AC evaporator core and get cold. I see a few servos on the side of the HVAC box (Toyota calls it the "Cooler Unit") to control the air flow, and likely the blend door.
Have you done any work under or near the dash? Carpet pulled up? Center console? The wiring to one of the servos may have been damaged or disconnected. Or perhaps the servo itself isn't working.
My truck, on defrost or defrost/floor, can still get way hotter than comfortable. Something is up with your truck.
Deleted User 412290
SR5 in WA here. Temps between 30-45 F recently. Takes a while to heat up, but is hot AF after it does. I regularly have to turn it at least halfway down after driving for 15+ min.
TRD6MT
Christian
CT
25 TRD Off-Road 6MT Celestial Silver
My heat is atrocious. Its been like this since I got it, thought it was just the truck. 30 Deg or less everyday the last week, driving it all the time as its my work truck - I've tried the following things and regardless of what I do, it doesn't blow hot air until the truck is driving 15-20 min
1 - Let the truck warm up in the driveway (heat on) 10-15 minutes before driving - No heat at all, blows cold air at me while its 15* outside until driving for close to 20min
2 - Start the truck let it warm up (heat off) 10-15 minutes, then try the heat - Nope, same issue as before, ice cold
3 - Start and drive the truck heat on right away - same issue. ice cold air for even longer this time
I've tried every different fan position, high heat, 70*, 75*, nothing. Something is wrong here. Toyota dealer looks at the truck and says nope no issue. Meanwhile, while I'm freezing my balls off driving to work at 5am when its 5 degrees outside I got a truck blasting ice cold air at me.
TRD6MT
Christian
CT
Meanwhile my 339,000 mile 02 Prerunner, that spent most of its life in AZ , has heat that could sweat you to death regardless of how cold it is outside lol. Love my truck not gonna sell it but the dealers are useless. Hoping a DIY solution comes about
BlancoTaco
BlancoTaco
Caleb
2024 Tacoma SR5
So a small percentage of us have inadequate heater output. One of us needs to figure this out since the dealership doesn’t care.
Will721
Quad Cities
Something I noticed playing with things, the heated doesn't work as well in Eco Mode while in auto. Blower speed has an audible and felt difference switching to normal. Could give that a shot and see if it helps.
Twodan
Southeastern Mass
2025 Taco Limited
Sounds as if you're in Auto mode.
I use auto mode once the truck has warmed a little. I set the temp to 78F and end up reducing it to 75F once I'm warm. And yes we have had cold weather this year.
