Does the TRD alumimum running boards PT738-35240 come with mounting hardware?
TRD6MT
Christian
CT
25 TRD Off-Road 6MT Celestial Silver
I picked up the TRD aluminum boards from the dealership today and there is no mounting hardware in the box. Are they supposed to come with hardware? and if so exactly what. I got the trd skid plate with red lettering as well and no bolts in that box either
PT738-35240
ixo
Rich
Antioch, CA
2024 Hybrid Tacoma OR Premium
AI seems to think they should come with the required fasteners
2024 Tacoma Does the TRD alumimum running boards PT738-35240  come with mounting hardware? 1765934243798-xc
I had the required hardware (and instructions) when I bought mine.
The skid plate mounting bolts are reusable with what comes on the truck.
TRD6MT
Christian
CT
My box was sealed with nothing in it besides the protective tape and shipping cardboard mounts. How much stuff did yours come with?
TRD6MT
Christian
CT
I believe the brackets and fasteners are attached but no instructions and no bolts
I can't remember exactly as it's been over a year, but it was a small parts box that had the hardware. They gave me the printout of the instructions.
ixo
Rich
Antioch, CA
fasteners are the bolts. that sucks, I'd just swing by a dealership with your receipt and the service dept can probably chuck you a bag of what you need.
bigd9247
Dalton
2024 TRD ORP, 2018 F150 XLT
My TRD OR came with those same steps installed. When I removed them and sold them to another member, we discovered that his TRD OR already had the bolts installed in the holes in the truck and he didn't need my bolts. Have you checked the mounting points on your truck? Those steps don't mount to the frame, they mount to the body under the doors.
TRD6MT
Christian
CT
Thanks for this info. I’ll check in the am it was dark when I got home that would be great. How long did it take to remove them?
I believe I may have originally told you wrong as I installed the tonneau and running boards at the same time. The tonneau does come with a small parts box. The running boards however use the (M8 I believe) bolts that are already screwed into the truck.
Yotota
SW WA
24 TRD
Please don't post "AI said..." answers. They're often incorrect, as the answer is wrong in this case.
AI is only furthering the enshittification of the internet.
I'm not trying to be a dick, I'm just against the AI BS that's becoming way too common.
I found the PDF of the install manual by searching "PT738-35240 pdf" (see attached). It confirms that no hardware is included and the bolts should be installed on the truck already.
bigd9247
Dalton
Maybe 10 minutes per side with a cordless impact. If I remember correctly, two of the mounting brackets are slotted so you can leave two bolts in the truck body and "hang" the running boards off those two bolts. Then you just put in all the other bolts and tighten everything up. I did it in my driveway laying on my back .
TRD6MT
Christian
CT
Very helpful thank you
Amorak
Oklahoma
2025 Tacoma TRD Pro, undergound w/ red interior
Yes. Mine were holding the "rocker protectors" that I took off.
Taco Ji
Banned
Banned
New Jersey
2025 Toyota Tacoma
Can confirm the existing bolts on the truck is all you need provided that you have an off-road trim which you do. If you have a sports trim then you need to buy a cross me we bracket and additional bolts.
