SXTH Element
Spartanburg, SC
2024 Tacoma, 2025 Tundra
Hey everyone, wanted to share a quick heads-up on an upcoming induction component we’re developing at SXTH Element Engineering for the 2024+ Toyota Tacoma (N400).
We’ve been working through airflow improvements on the Gen 4 platform, and one of the first standalone pieces we’re bringing to market is our Turbo Inlet. It’s currently in the coming soon phase, but we wanted to give the community an early look.
What It Is
This turbo inlet is a direct bolt-on replacement for the factory inlet, designed to reduce restriction and improve airflow into the turbo. The goal is to smooth the airflow path compared to the OEM piece, which should help with turbo response and overall efficiency once installed.
Coming Soon - 2024+ Toyota Tacoma Turbo Inlet – SXTH Element
Key Features
  • Enhanced airflow through optimized internal geometry to reduce turbulence
  • OEM fitment using factory mounting points and sensors
  • Durable, high-temperature materials designed for under-hood conditions
  • Black finish that integrates cleanly into the engine bay
Why You Might Want It
The factory turbo inlet prioritizes NVH and packaging, which often means compromises in airflow. This inlet is designed to remove some of that restriction while maintaining OEM-level fitment and reliability, especially for those planning intake or turbo-related upgrades.
Current Status
This product is still in development and listed as coming soon. No dyno data or release dates to share yet, but we wanted to put it on your radar as we continue finalizing production.
More details to come as things progress.
rallyprox
Scott
Northern California
2025, TRD Off Road, MT
Good to see more options coming to market.
Any word on noise level changes and CARB approvals?
Wife bought my 24 TRD
Anthony
Aberdeen Wa
Different piece.
This one goes from charge tube to the throttle body.
It's a super pain in the BUTT to get to this one last fastener of the 4 on it too.
So if I am going through all that to change 1 more piece, I will choose to save another 5k, and change the intercooler, and all the pipes l, along with the turbo, tune, and add a tranny cooler.
After I finish cutting up the rear of the truck for a major upgrade in the spring I pray by summer I will go after the engine.
One thing I know is at this point in my life (56 and retired), I have made enough good choices throughout life to be able to, buy, and build my truck without debt.
I have done it the other way, building my first 1983 SR5 Toyota monster, going into debt as a young man, and worked a lot of my life away too pay for.
I DON'T RECOMMEND DOING IT THIS WAY.
JuanitoBonito
Juan
Chi-town
I’m in the exact same boat. At the cusp of turning 52, I’ll retire in a year and a half shortly after turning 53. Ill be able to play and mod this truck at will without going into debt.
Anthony
Aberdeen Wa
At the risk of sounding old and showing signs of wisdom, ( because I knew everything in my 20s )
I wish I would have listened to everyone, save your money too pay for your mods out-of-pocket, instead of going into debt to work your life away and not be able to enjoy.
Ace-ington
Different piece.
This piece goes from your current intake tube to your turbo inlet(front center of the turbo) not to your throttle body that is the other side of the engine. It pretty much replaces the big plastic piece in front of your turbo which has vacuum lines connected to it. It completes the sxth element intake too if you already have the intake. I had the K&n full modular intake (which replaced everything all the way up to the inlet of the turbo) it made alot of noise compared to the sxth element one (but the k&n was throwing codes cause of a crappy design) so I can imagine this one will also make your turbo spooling sound even louder.
Rendusk
Marv
Port St Lucie, FL
Tacoma 2025
Oh man, you're right.
Idk why back when I read this, I read as the elbow for the other side.
Thanks for the correction!
I'll edit my original post tp prevent confusion.
gmalkmus
SW Missouri
2025 Tacoma TRD Offroad 6MT, 2015 Mustang GT 6MT
Stoked for this, hopefully it'll give even more turbo sounds than just the SXTH intake alone (which sounds sick, don't get me wrong).
I am really excited for the SXTH full exhaust too. Are you guys taking any design requests from the community for the exhaust? I think dual 4.5" tips (like the AWE) would look sweet, and definitely needs some sort of j-pipe/quarter wave resonator to tame any drone.
