RangerTub3
KY
I checked a dealer web site and it states the following:
NOTE: Verify the presence of welded collars at the rear of the frame. This part will NOT work if your vehicle is not equipped with welded collars. (Vehicle will have plug covers instead of welded collars) .
My 2024 tacoma has plugs which i haven't removed but do i take it since i have plugs this part from Toyota won't work for rear arb recovery points?
TX-MD
marvin
AR
Tacoma, 4Runner
Those that have installed these - I was thinking they bolted into threaded holes in the hitch frame, but now realized it is a nut/bolt combo. Was looking under the truck today and wasn’t sure if I actually have the collars already? Could someone that has collars verify my L/R side that these are the correct mounting holes, and they have collars? Thanks
2024 Tacoma Install of ARB Rear Recovery Points on the 2024 Off Road Premium IMG_4208
2024 Tacoma Install of ARB Rear Recovery Points on the 2024 Off Road Premium IMG_4207
PNWkip
2025 DCLB SR5
My understanding is that they are not correct and we would need sleeves/pins like @gtguard has. But will be stoked if I am told I am wrong! I want to get a set of these.
rijc99
I can’t see the outside part of the frame as the arb recovery is covering it but if it is collared you would see this on the inside side of the frame. You can see the reinforcement of the collar welded to the sleeve and frame.
2024 Tacoma Install of ARB Rear Recovery Points on the 2024 Off Road Premium IMG_5586
TX-MD
marvin
AR
Tacoma, 4Runner
Thanks rijc99, I’ll snap some pics on the inner side of the rails when I get a chance.
TX-MD
marvin
AR
Tacoma, 4Runner
2024 Tacoma Install of ARB Rear Recovery Points on the 2024 Off Road Premium IMG_4220
2024 Tacoma Install of ARB Rear Recovery Points on the 2024 Off Road Premium IMG_4221
Inside L/R shots of the rail, looks like something is welded on. Are these the proper reinforcements for the rear recovery points? Sorry it was dark out so pics aren’t the best
