ARB Ascent Canopy (Photo Heavy) with Base Rack
Chukwithak
Charlie
ID/CA
25 Undergound DC i-FM OR
I FINALLY got everything in and put together. There were a couple of headaches along the way.
Almost every photo that ARB posted on their website, as well as social media, with the Ascent Canopy Base Rack shows that the rack length is the same as the canopy and no longer.
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack Screenshot 2026-06-18 at 3.40.50 PM
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack Screenshot 2026-06-18 at 3.41.00 PM
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack Screenshot 2026-06-18 at 3.41.33 PM
These are from ARB's website. The only different one is the overhead view, and I'll explain later.
After waiting 7 months, the base rack finally arrived in the States, and I placed my order based on ARB's site and Tacoma Canopy's specific listing. What I DID not realize, because it's not stated anywhere, is that the base rack listed as the APPROPIATE rack for the Tacoma/Ascent Canopy is a 6 crossbar at 61".
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 8BE7E94C-ED9F-4213-A211-E5339B71BFAE_1_102_o
The flip side of this 61" Base rack is that it CAN extend over the double cab, but my issue is that I already have a rack. While I might have a couple of millimeters of clearance between racks, any truck flexion would put stress on the internal frame and shell because they're integrated.
After talking to ARB, they stated that the design was to have a 61" Canopy Base Rack in the back, extending slightly over the cab rack and resting on the 61" Tacoma "over-cab" base rack. None of this makes much sense to me.
After talking to ARB techs, I found that the BASE Rack 49x45 1770060 is a 5 crossbar that is 1" narrower and fits perfectly. It is likely the one used for promotions. I switched to this Base Rack because it feels appropriate.
I had Camburg support brackets and a Decked system before this installation. I did not realize the Camburg arms would need to be removed for the Ascent internal frame, which likely serves a similar purpose to the Camburg brackets. I was able to cut the side wings of the Decked and make it fit perfectly.
Also note that the instructions ask you to refer to the "Drilling" instructions, as you need to drill 8x40mm holes into your shell for gaskets that retain pressure between the frame and base rack, so the canopy does not crack.
These drilling instructions do not exist yet.
I used a pair of calipers to get the appropriate dimensions and a step drill bit. If my memory serves me right, I got 19mm (0.74"), and I drilled to 3/4" on the step bit. It worked perfectly. You also need a non-acetic (?) sealant, such as Silka-flex 221.
Long story long, my setup and suggested setup is:
Core page for Acsent Canopy for the Tacoma
Ascent Truck Cap BASE Rack Blade Kit - Blade kit for the Ascent Canopy
Ascent Truck Cap Internal Frame and Tub Brace - The images shown are not the same as those received.
BASE Rack for Tacoma (2024+) - 61x46 - Suggested Canopy Base Rack by ARB (not me)
BASE Rack - 49x45 - I recommend the 5 Bar Crossbar rack, which is often featured in promotional shots.
* Something else interesting I noticed is that the two part numbers are VERY similar.
BASE Rack Kit for Tacoma (2024+) - 61 in x 51 in - Over cab 1-piece design.
BASE Rack Kit for Tacoma (2024+) - 61 in x 51 in - Over cab 2-piece design.
* I'm unsure why they made these two different racks. ARB is moving, and it took a week to contact a tech. These racks sit lower than the canopy's base rack, so a flush fit from front to back isn't possible. I'll update this if I find anything else.
I love the shell! I love the rack and the design. My ONLY gripe is the discovery, the lack of information and instructions, and why it isn't flush from back to front... Everything is well designed, though, and I can't wait to get the tent on, as well as some accessories.
Maybe @ARB 4x4 will chime in when things settle down.
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 43A64A83-0580-49BB-9F48-EC1DA1C15A58_1_105_c
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack DE0AF3E3-0A07-4706-9B03-95D9613B1BC9
P
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 705032D4-C5A5-4E7D-B9CF-AB5DCCC5DF3D
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 1721A5E4-447E-46C4-BD71-46043F66EE12
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 6DFEE1B4-C3EC-4CA5-9765-C0F4B89D7BAA
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 343F4B3E-73C7-42FE-858A-FEEDCFB39C2A
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 2876B50D-83A1-4BDC-A391-E62AD4269710
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack FD541D76-038B-49BE-8FF8-ED8FF996C9A6
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 03A16E0F-13A8-4D10-9ED9-3BA097785B85
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 7A51C8F8-A26B-4391-8389-9E964B2D3354
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 3D51581F-1C50-4C5A-9B86-23B7703FE809
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack B0FD24D4-5F5A-4782-AFD3-63F7DEE23F3F
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 471AAF07-BB7E-4D2E-BC22-B25389872505
2024 Tacoma ARB Ascent Canopy (Photo Heavy) with Base Rack 7658513A-3FF6-4746-A942-24BC3091B2C5
poseytaco
Nicholas
Southern Indiana
2026 Toyota Tacoma Off Road
How was the install of the canopy itself? I’ve been trying to get information about it for a while now, but haven’t had much luck. Doesn’t seem like there are many out there yet.
Chukwithak
Charlie
ID/CA
There are not. I had to buy it in Canada because the US shipments were delayed and Cap-it was required to install it. Wouldn’t let me do it. It was more work than I expected, but only took them a couple hours and it was there first one. I think the biggest shock was having to sand down the bed rails so the top surface is flush for a seal. Have you seen the instructions?
gmalkmus
SW Missouri
2025 Tacoma TRD Offroad 6MT, 2015 Mustang GT 6MT
That's a real nice "RD Offroad" you got there haha. What happened to the "T"?
Chukwithak
Charlie
ID/CA
Haha, haven’t finished taking off the stickers. They’re not like the old ones that are easy to remove. New ones are different type and much harder to remove.
poseytaco
Nicholas
Southern Indiana
Your canopy setup looks awesome. I forgot to put that in my original comment.
Yes. I have read the instructions. I have also contacted 2 vendors for information on the canopy with no luck. They are clueless about anything that has to do with it. You would think ARB would educate the venders selling this product. Especially since it’s fairly expensive. If it wasn’t such a nice piece of kit, I’d be looking elsewhere.
Chukwithak
Charlie
ID/CA
Contact Cap-itLangley location. +1 604-857-1211. They were super helpful.
I had the Leitner rack on my 3rd gen, Smartcap on this one, then the ARB. Smartcap was trash in comparison. Leitner was bomb proof but feel like you lose a lot of space and dust. I’m VERY happy with the ARB now that it’s dialed but it’s been an absolute pain to get things resolved properly. Would I do it again? Yes. In an instant.
poseytaco
Nicholas
Southern Indiana
Thank you for the contact. From what I’ve read, I should only need the canopy. I will not be adding the internal bracing unless it’s necessary. I don’t plan on carrying anything on top.
Having to sand the rails down does seem a little extreme. You would think there would be a more flexible gasket material that would seal better. Any other issues you ran into when installing? Also, is the canopy made of a type of plastic material? Thanks in advance.
Chukwithak
Charlie
ID/CA
If I had to guess, it’s fiberglass like a Snugtop. Installing the control box was interesting but worth it. Everything unlocks with the truck. ARB support was very helpful. If you run into any hiccups, feel free to reach out. If I know you’re working on it all be more attentive too.
poseytaco
Nicholas
Southern Indiana
I ordered the canopy today. If you are serious about giving me some pointers on it when it comes in, I’ll happily take you up on it.
Chukwithak
Charlie
ID/CA
DM me your cell number and I’ll shoot you a text.
poseytaco
Nicholas
Southern Indiana
Pretty sure I messaged you. Still trying to figure this app. out. Let me know if you got it.
