Do we need a front lower grille mesh on Tacoma 2024+?
Lexland_Official
Devin
Tacoma TRD Sport
This Tacoma Front Lower Grille Mesh is designed specifically for 2024+ Toyota Tacoma models. It offers a precise, vehicle-specific fit for easy installation and reliable protection.
Here are the reaseon why we recommend this product below! ! !
Best Seller Style
Upgrade Your Vehicle's Protection! Keep rocks, bugs, and road debris away from your radiator with the Lexland Metal Radiator Bug Screen. Enjoy maximum protection, unrestricted airflow, a perfect factory fit, and fast, no-drill installation.
Save Money
-Protect Your Radiator. Save on Costly Repairs. Lexland's heavy-duty metal bug screen shields your cooling system from everyday road hazards while maintaining optimal airflow and factory performance.
-Built for Protection. Designed for Performance. The Lexland Metal Radiator Bug Screen combines durable metal construction, a precision vehicle-specific fit, and hassle-free installation to keep your radiator protected mile after mile.
-Don't Let Road Debris Damage Your Radiator! Choose Lexland for long-lasting metal protection, factory-level airflow, and an easy 15–30 minute installation. Drive with confidence every mile.
Lexland 20% Coupon Code: Tacoma4g
Tacoma Front Lower Grille Mesh Insect Bug Screen Radiator Guard: https://lexland.com/yshgvk
Slappy
tacoma , highlander
hmmm i lost a radiator in my 2001 1st gen Taco due to the huge gaps in the stock grill that a rock got thru .
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Decided to give this a try. It doesn’t block much of the grille, but it blocks the bottom front entry, and I do get a lot of gravel and bees in there…. This was a very easy installation.
I was being careful not to over tighten to avoid deformation of the OEM plastic grille trim that the brackets sit in front of on their midsection.
One thing I realized was that I could micro adjust the brackets up and down, not just side to side, to get the best fit. But things still shifted slightly while tightening, so I had to back off a tad, then tightened a little at a time on each bolt.
The silver hardware that comes in this kit looks ugly IMO, so fortunately I had a black hardware kit on hand with M2 button head bolts. They were just slightly longer with a couple of extra threads, but that didn’t matter because there was enough open space behind the bolt holes. Pic of hardware kit is included, which I bought on Amazon for $19.99 USD. For a link to Lexland’s kit, look at the beginning of this thread. They also posted a link to their website and a forum discount, but Amazon may be lower cost through another seller (that’s how I got mine; link is also below.)
Fgruh 2200PCS M2 M3 M4 M5 Metric... https://www.amazon.com/dp/B0FGX9JGC5?ref=ppx_pop_mob_ap_share
Front Grill Vent Mesh Cover... https://www.amazon.com/dp/B0FLNXJ7XD?ref=ppx_pop_mob_ap_share
Slappy
tacoma , highlander
thanX 4 links
seems their website didnt like my cc
which is a big red flag as it works everywhere else
& i rather order from Amazon anyway
lauren01
Lauren
Ventura, CA USA
thanX 4 links
Agree 100%! We keep hearing they’re shady AF. This too-expensive, couple of thin bits of black-painted, framed wire with bolt holes will work well until such time as I decide on a possible winch bumper.
Slappy
tacoma , highlander
i feel it is insurance on the inter cooler
i lost a rad in a gen 1 had to get towed & missed a days work . The Gen 1's have huge openings in that grill
so yeah rocks happen 😡
i wish they made a nylon net that we could add behind the main grill
Will721
Will
Quad Cities
2025 TRD OR
Its funny people are just now discussing this sort of thing in 2026. Every car ever made has had this issue clear back to when we first went to liquid cooling. Even motorcycles are predominantly liquid cooled now and have the same issue. Any form of heat exchanger has to be made if thin/soft materials because of the thermal transfer properties of different metals. You can't really use steel even though its cheaper. Brass, copper, and aluminum have always been the required materials.
Interesting enough though, the only engines which typically offer any kind of protection from debris are on the slowest moving vehicles, tractors. Mesh screens have been standard use for decades. Although not typically strong enough for impact protection, they are actually for grass and leaves. They move so slowly and hardly ever see the road so having a screen to prevent foliage from clogging up the radiator is quite handy. They also move so slowly in dusty conditions I have specific water hose attachments for blowing the dirt and mud that builds up in the cooling pack, and an air one to dry it after.
franx
Frank
Lehigh Valley, PA
2025 Tacoma Limited Hybrid
I contacted the manufacturer and they said they screws are black now. After reading an earlier post I wanted to see if they changed.
I may install this after reading about others having rocks punctures.
lauren01
Lauren
Ventura, CA USA
Something changed in the last week? Hmmmmm.
