Delirious
Nick
Do you not have the homelink buttons on your rearview mirror for programming garage door openers etc?
Someone can bust out your side window without setting off the alarm and reach in there and hit the Homelink button, open your garage door and come in and do whatever whenever. I never use the Homelink. Maybe now they've disabled it when the ignition is off but I doubt it. I don't know. What I've done in the past was similar to what this OP did except I used a momentary contact button. It was hidden in the dash so if somebody broke in, they wouldn't have found it. Here's a YouTube video on how to do that....
Hidden garage door button
W0xie
Idaho
2024 Tacoma Sport 4x4
That looks great. The blank next to the bed light switch is just about the right size for the standard momentary rocker switch.
2024 Tacoma Garage door opener mod: installed as dash button (in 2024 Tacoma TRD Sport) IMG_0042
2024 Tacoma Garage door opener mod: installed as dash button (in 2024 Tacoma TRD Sport) IMG_0043
TacoGomez
Jay
The angled panel underneath, with the bigger switches slides up towards you. You then have access to the blanks from under them.
I’m following your design but am having trouble (nervous about breaking something) removing the angled panel. Do I pry it out or is there a trick? Thanks for any help
Tacoflvrd
Tacoflvrd
South carolina
2024 TRD sport
So you kind of have to pull down on it slightly while you also pull it up towards you. It slides out and up.
TacoGomez
Jay
Got it! Thank you. I ordered the button from aliexpress. Great idea and it looks great
2024 Tacoma Garage door opener mod: installed as dash button (in 2024 Tacoma TRD Sport) IMG_4457
Tacoflvrd
Tacoflvrd
South carolina
2024 TRD sport
Looks good. I may go and order that as I want to use the flux capacitor switch for something else.
TacoGomez
Jay
Did you run power to the opener or just keep using buttons? I ordered a power converter but it hasn’t arrived yet. Not sure I’ll bother with it until the battery dies
TacoGomez
Jay
Not buttons, I meant battey
Tacoflvrd
Tacoflvrd
South carolina
2024 TRD sport
No I just left it with using the battery in the remote. I figure it will last quite a while and don’t mind changing it out every once in a while. It’s easy enough to get to.
Suzay
Hawaii
2024 Tacoma sport
Can you just add a Homelink mirror?
dvrgz
Los Angeles
I wanted to get rid of my garage door opener on my visor and hide it with an oem looking button. Since I’ve got lots of poverty buttons, I have plenty of space.
I couldn’t find a momentary “Garage Door” button. So, I order a “Flux Reactor” 20x20 butting from caliraised led. I ordered a two pack of garage door openers from Amazon and opened one up. I’m pretty terrible with electrical so just stripped the wires I needed and touched them to different legs on the switch until the led lit up.
once the rain stops later this week I plan to wire up the switch for the backlight led.
Did you order that flux capacitor button and light bar button? If so where did you get it ?
