24tacoman
2024 TRD OR 6M
This video gives some great insight on how the T24 is actually proving itself to be a better motor with less problems than the outgoing v6. Many are quick to bash it because it is a 4 cylinder with a turbocharger but it seems like this engine has the potential to be an ultra reliable Toyota 4 cylinder. It bothers me that so many folks automatically paint the T24A with the same brush as the V35A without doing any research despite these being such great engines with next to no widespread issues.
I love mechanical breakdowns like these because they are actually based on facts and experience rather than the personal uneducated opinions of armchair mechanics...
Text summary (via AI)
The Car Care Nut argues that while Toyota's twin-turbo V35A V6 has overshadowed the brand's turbo reputation with major failures, the 2.4L 4-cylinder turbo (T24A-FTS) is quietly establishing a strong track record with no chronic failure patterns.
Why He Thinks It’s a "Rising Star of Reliability"
  • No Chronic Failure Patterns: Unlike newer problematic powertrains, the T24A-FTS has already accumulated high-mileage examples (even with some owner neglect) without exhibiting widespread, systemic defects.
  • Old-School Mechanical Simplicity: Toyota avoided unnecessary complexity in key areas. It uses a single timing chain with an internal hydraulic tensioner, a mechanical belt-driven water pump (even on hybrids), and standard roller rockers and hydraulic lifters without cylinder deactivation.
  • Vacuum-Actuated Wastegate: Instead of placing fragile, plastic-housed electronic wastegate actuators directly next to scorching exhaust heat like most modern turbos, Toyota used a classic, reliable 1990s-style vacuum-operated diaphragm wastegate.
  • Redesigned Two-Piece Timing Cover: To eliminate Toyota’s notorious "tri-corner" timing cover oil leaks where the block, head, and cover meet, Toyota engineered a two-piece front cover that routes oil passages away from that seam.
  • D-4S Dual Injection: By combining direct injection with port injection, fuel washes over the back of the intake valves, preventing the severe carbon buildup that plagues direct-injection-only turbo engines.
  • Exceptional Serviceability: Unlike cramped V6s (such as the outgoing 2GR-FKS) where major repairs nearly require pulling the engine, the T24A-FTS has wide-open access in the engine bay and no overlapping covers. He compares its ease of maintenance to classic Toyota four-cylinders like the 22R.
Configuration Differences & Minor Drawbacks
  • RWD/Truck vs. FWD/AWD Layouts: Rear-wheel-drive truck configurations (Tacoma, Land Cruiser, 4Runner) use a simple, old-school air-to-air intercooler, whereas transverse front-wheel-drive platforms (like the Lexus NX) use a more compact liquid-to-air intercooler integrated into the intake manifold, which adds a second cooling loop.
  • Hybrid Setup (i-FORCE MAX): The core mechanical engine is identical, minus a belt-driven AC compressor and alternator. Crucially, Toyota kept a traditional starter motor as a backup so the hybrid electric motor doesn't violently spin a dead-cold engine straight to 700–1,000 RPM in freezing temperatures before oil circulates.
  • Small Complaints:
    • Direct Injector Placement: While the top-mounted direct injectors are easy to reach, they sit on top of the valve cover—meaning you have to pull them (and replace their single-use Teflon combustion seals with special tools) just to remove the valve cover.
    • Rear Vacuum Pump (RWD): Because direct-injected engines generate low manifold vacuum, a mechanical camshaft-driven vacuum pump is needed to run the turbo wastegate; on RWD trucks, it is tucked at the very back of the engine.
    • Plastic Coolant Fittings: Toyota used more plastic quick-disconnect coolant fittings than in past generations, though the tubing itself is high quality.
Maintenance Rules to Make It Last 200k–300k+ Miles
The host emphasizes that the engine has the hardware to hit 250,000–300,000 miles, provided owners do not treat it with typical Toyota neglect:
  1. Break-in & Strict Oil Intervals: Perform a break-in oil change at 1,000 miles, then change the 0W-20 oil every 3,000 to 4,000 miles (not 5,000 or 10,000) using quality oil and an OEM Toyota filter.
  2. Frequent Spark Plug Changes: Replace spark plugs every 40,000 miles. Only use OEM Toyota plugs—aftermarket plugs have already been seen causing issues, and the job takes only 15–20 minutes due to easy access.
  3. Coolant & Belts: Drain and refill the coolant every 50,000 miles or 5 years, and keep an eye on the easily accessible drive belt and tensioner.
GR8Santini
TX
‘26 Land Cruiser, ‘25 Tundra TRD OR, ‘26 Tundra Hybrid LTD TRD, ‘97 F250HD 7.3L
Starting to see sub $20/ea spark plug on NGK DILZKAR8E7H.
Used to be $54/ea for 90919-A1008 from Toyota.
GR8Santini
TX
Without used oil analyses, I'm taking the frequent oil change bit with a grain of salt. That's very outdated thinking.
Hardly. Been using 5W/30 for the conditions. 2015 GX460, ‘23 Sequoia, ‘25 Tundra w/ OE TRD Perf Pkg (421HP), ‘26 Tundra Hybrid, & ‘26 LC T24A.
0W/20 was factory fill & @ first oil changes @ 1500 miles switched all of them to 5W/30 Mobil 1 w/ OE Toyota oil filters & can of Liquid Moly anti-friction treatment. Absolutely not following the 10k service intervals.
Do as you think is right for your conditions. Just me - our vehicles are operated in Texas cold & heat, @ higher highway speeds, towing, off-road, ranch roads, bad stop-n-go traffic (when we slow down), lots of idling, & all are 4WD or AWD. By the way, 15 years ago that sentence was the definition of severe duty use.
Should for some reason I miss a 3500-5000 mile interval oil change, 0W/20 could be starting to break down in those conditions, so 5W/30 keeps me in safer position.
Your maintenance guide pages say RECOMMENDED, not required.
GR8Santini
TX
Then do used oil analyses so your claims aren't just hunches and speculation.
You realize a 5000 mile oil change is cheaper than getting Lake Speed oil analysis - right? Have you looked @ research from oil analysis on when 0W/20 starts breaking down, & why? Or, researched into that 5W/30 is in other Toyota markets as an alternate for higher temps - in the same engine produced in the same factory? There are no hunches or speculation, & I’m not following along to anyone’s internet wisdom. I did my homework & fairly seasoned in experience. And yes, I do Blackstone on my Lycoming & Continental aircraft engines.
24tacoman
24tacoman
2024 TRD OR 6M
I have done just this on my 2024 and it proved that under the same conditions, 5w30 is an improvement over 0w20 on this engine. This same engine is specced for 5w30 across the world with no mechanical differences, and the only reason to run 0w20 is if you live in an area with extreme cold (below -30C regularly). Otherwise 5w30 is a better oil for this motor. It is nothing to be afraid of.
2024 Tacoma The Car Care Nut Video on the T24A-FTS engine as a "Rising Star of Reliability" Oil Analysis
AmbyBomb
Nick
Alberta, Canada
2026 Tacoma TRD Sport
Good info, but the debate isn't about 0w20 vs 5w30. The mechanic in the video says the engine oil should be replaced at less than half the mileage that Toyota recommends. That's the part I take issue with.
24tacoman
24tacoman
2024 TRD OR 6M
Totally depends on use case. If you are doing all long highway driving unloaded and live in a warm climate (no fuel dilution), then maybe 10k intervals would work. But any other conditions like short trips, heavy towing/hauling, cold climates, lots of cold starts, or stop and go traffic situations then 5k intervals would be the maximum safe interval. Toyota even says so themselves if you look at their definition of "severe" use cases. In my truck personally, I am doing 5000 km (3000 mi) intervals but I live where it gets extremely cold (Northern Manitoba) and do frequent short trips. Oil is cheap(ish) and engines are very very expensive nowadays. I use Blackstone every once in a while on the truck and have had good luck using them for a Continental O200 I used to own as well so I trust the data. Fuel dilution scares me with these engines.
AmbyBomb
Nick
Alberta, Canada
I would still like to see actual, objective evidence, like used oil analyses, before saying 30% of the normal, recommended interval is what you need on a modern engine running modern oil.
TacoPickles
Miami, Fl
Tacoma Trailhunter
Outdated perhaps when talking about natural aspirating engines. Turbo charged engines absolutely chew up motor oil. Don’t let your grain of salt prevent you from actually doing h the research .
GR8Santini
TX
Your words - ‘Normal, Recommended’.
My words - Severe Duty Use.
