nurp42
TRD PreRunner
Jeff
'24 PreRunner
I decided the ICON Top Hat seemed like a good investment.
Click link to look at my install pics
I thought good investment as well and purchased them a while back, but haven't had a chance to install yet (insert bag on head emoji here if there was one :)). Nice job!
HoptownBob
HoptownBob
Bobby
Hopkinsville, KY
2024 Tacoma TRD Sport Premium
14mm deep well socket, a couple 6” extensions, 3/8 ratchet, a 14mm combo wrench and a drop light. About 30-40 minutes
What is this for?
Protection.
The top hats (at least on the early 24 models) are weak and have seen a few cases where they are broken and the shock pushes through. These are steel reinforcement plates that sit on top the top hat.
Old Trucker
Ted
Long Beach, CA
2022 BMW X3 M40I; 2025 Tacoma TRD Off ROAD IMax Hybrid
Protection.
Thqanks for your response.
Steelman 56
South Jersey
2024 Toyota Tacoma TRD Off Road
I also installed the Icon reinforcement plates. After installing I wonder if these plates are installed and one would have a failure of the casting how would you know? What if you are driving around with a cracked shock mount but can't see it because of the Icon plate. I had reached out to Icon for their thoughts, but it was obvious that it was easier to get in touch with the White house. I never did get any feedback. Thoughts from the real world please?
As noted above, the early trucks saw some failures. Tacoma fixed the issue.
Did they? Not that I've looked at any new models, but I haven't seen anything different that they're no longer using cast.
Did they?
Well, the problem disappeared.
Toyota doesn't sit on its butts after a new release.* If they see a failure trending, they fix it. It would be stupid to keep manufacturing things that break during warranty. Expensive and a death to their reputation.
Several people reported this failure on the forums early on, but those reports subsequently ceased. How they fixed this part, I have no idea.
I recall the first rear brake line failure that hit the forums. A guy from Fairbanks had driven the haul road, and mud caused his brake line to fail. The dealer said it wasn't covered. Toyota flew in an engineer, and they chose to cover it. I recall another problem that Toyota flew in a team to look at the issue, but I don't remember what the problem was. Perhaps it was this.
realbert
Eric
Pittsburgh
2024 Tacoma Off Road
I've wondered the same thing and settled on the uninformed notion that with the "hat" as I like to call it, the casting would have no room in which to stress and eventually break. The hat does not hide the failure as much as prevent it.
Tacoyaki
Tacoma TRD Off-Road
I had them installed at the same time as the front Alldogs springs. While it doesn't prevent the failure, I need to know I can drive back safely should the failure occur.
Steelman 56
South Jersey
That's funny. I also installed mine that the same time I installed the Alldogs spacer erasers all around. Good Point you make. Because these are easy to access that perhaps once a year, I would remove them to inspect the castings for breaks or cracks? I think this will be my approach going forward.
HoptownBob
HoptownBob
Bobby
Hopkinsville, KY
Protection.
Actually billet aluminum
