JayTech
Jay
2025 Toyota Tacoma TRD ORP
I work at a Toyota dealer and have been seeing many complaints about a driveline vibration at speeds below 50mph and no one has been able to fix them with the dealers most people have been going to being of no help. It seems most would either say it is normal or try to balance tires with most vehicles vibrations not being fixed.
We had a couple arrive with this issue at our dealer starting with a brand new Trailhunter to be sold on our lot so we started by balancing the tires, swapping the rims and tires with another truck with known good wheels/tires, and then tried removing the shaft and test driving it in 4 High. We found the vibration went away with the rear shaft removed so we have isolated the problem to being the driveshaft. We then tried the same thing, removing the shaft and driving in 4 high on the other trucks and it has solved the vibration for all of them. So far all cases of the vibration problem we have experienced have been Tacomas with the 2 piece rear driveshafts(6ft bed), so there definitely appears to be an issue with the rear driveshafts. Replacing the shafts with new units has solved the vibration concerns in all of the Tacomas we have had in for this problem.
This may also apply to some people experiencing the same vibration in the 5ft bed Tacomas with a single piece shaft but we have not had any in with this concern yet to verify if that is the case or not. One of these trucks the rear shaft pushed the rear end out of alignment so this may also be why some people are seeing the rear end out of spec while also experiencing a slight vibration.
Hopefully Toyota addresses this concern soon and hopefully this will help some of you experiencing this issue and pointing out this being a known issue to the dealers if they try to tell you "this is normal", as this is definitely NOT normal.
EatMyTaco
Murica
2026 Tard OffRoad
Wow! Isn't driveshaft balancing part of the manufacturing process when they're machined?
JayTech
JayTech
Jay
Thanks for this information! I'm dealing with a similar vibration in my double cab long bed Taco.
I'm curious if it's a design flaw, since it's occurring on all model years of 4G Tacomas. They are manufactured by Spicer who is usually known to make good stuff...
Not sure. It isn't every truck and it also isn't within a set production period either(which would indicate maybe just a bad batch) so I am wondering if something in the design is an issue or if this is going to be a bigger problem.
JayTech
JayTech
Jay
I do not think this is a balance issue itself but a problem with either the shape/straightness of the shaft or some other problem. Other shops have tried balancing the shaft and it isn't out enough to cause the level of vibration we were seeing. That leads me to wonder if they aren't entirely straight which could also explain why it is throwing the rear end out of alignment.
JayTech
JayTech
Jay
Interesting. I may need to take my truck to a flat area, pull the rear shaft, and drive it. I live in the hills and don't want to overly stress the front diff.
I know that @Reptar had this issue, got a new shaft, but the issue remained...
Because there are new trucks off the lot experiencing this issue I can not say for certain that the replacement shaft itself will be any better until you install it, but so far the ones we have installed have taken care of the problem. Hopefully Toyota addresses this issue with an updated part, TSB, warranty enhancement program, or recall.
4g hybrid
Was this at all speeds and conditions? Or only specific speeds, rpms, or scenarios?
JayTech
JayTech
Jay
Vibration was most noticeable under 50mph, with 20-30mph being the most harsh. But the vibration was there all the way up to highway speeds, it just became less harsh.
JayTech
JayTech
Jay
I'm happy that SOME Toyota techs are taking this seriously - thanks for actually caring! Hopefully this information makes it up the chain at Toyota and Corporate does something about it.
As I'm sure you've seen, most techs are not nearly as dedicated to doing their jobs to this level...
To me this is the norm. I am more genuinely shocked reading all the posts about how techs aren't finding the issue or going to the lengths to figure out what is wrong and instead saying "this is normal" or "no fault found". This was also the case at the Chrysler dealer I worked for.
My dealer has a meeting coming up with our regional manager and I plan on bringing this up to him to try to get Toyota involved into looking into this, if they aren't already as just claiming a part on warranty won't be enough to get this investigated(Needs to have more wide spread warranty claims for them to start an investigation).
Cabby30
CA
2024 DCLB TRD OR
Are the hybrid and non-hybrid rear driveshafts different SKU's? I would think so just based on the different differential size but I do not know.
NH Marine
Marvin
New Hampshire
2025 Tacoma SR5 6' bed
I have a 2025 SR5 6 ft bed. Just bought it last month. Brought it in for this issue (I get the vibration between 30-40 MPH). Drove it with a Tech who said it was from the transmission struggling at low RPM's. I told him it did it when coasting, driving steady, in nuetril, down hill etc. I then went up to the Manager who is opening a case with the Brand Engagement Center. I am waiting to hear back from them.....
This weekend thought I had an interesting event. I put 600 LBS of weight in the bed to move. When driving with it, the vibration almost completely went away. When I unloaded it, it came back.....
JayTech
JayTech
Jay
Yes. There are 6 different driveshafts that I can see listed for 6ft bed trucks. And another 4 for the 5ft bed trucks.
JayTech
JayTech
Jay
I have a 2026 SR5 6 ft bed. Just bought it last month. Brought it in for this issue (I get the vibration between 30-40 MPH). Drove it with a Tech who said it was from the transmission struggling at low RPM's. I told him it did it when coasting, driving steady, down hill etc. I then went up to the Manager who is opening a case with the Brand Engagement Center. I am waiting to hear back from them.....
When you hear back from them, I would let them know other dealers have found a problem with the driveshafts so they can inspect to see if that is the same case for yours. This definitely seems to be an ongoing issue seeing there are MANY complaints of driveline vibrations.
JayTech
JayTech
Jay
I found two different part numbers for the 2pc rear propellor shafts on longbed, automatic transmission trucks:
37110AK010 - 2024 SR, SR5, gas only; 2025 SR, SR5, Limited, gas & hybrid.
37110AK040 - 2024 & 2025 TRD OR, gas & hybrid.
I wonder if we can isolate the issue to one specific part number?
37110-AK040 is for the 5ft bed. That is the driveshaft in my Off Road Premium Non Hybrid 5 Ft box. 37100 part numbers are usually 2 piece shafts while 37110 are the one piece rear shafts.
The issue isn't isolated to just one part number as we have already done the Trailhunter exclusive 37100-AK020 shaft, and 37100-Ak010 shaft in a couple sports.
JayTech
JayTech
Jay
Damn, looks like Partsouq failed me for part number!
But you've already looked into my idea. If it's not isolated to one propellor shaft part number, then it's an overall design or manufacturing issue.
Yea we looked into that when we had the Trailhunter with the vibration in and wanted to see if it was the same part as the other ones that were having issues.
BLtheP
TX
Interesting. I have the two piece steel driveshaft on the short wheelbase due to the MT. Best I can tell, my driveshafts are the exact same length as the 4x4 AT SWB, so I never understood why mine is 2 piece while the equivalent AT is not, but regardless mine is smooth as silk at all speeds with no vibes, so whatever they did, they got it right on mine.
They had issues with rear shafts on the 3rd gen as well (common recurring theme); wonder why Toyota can't figure this out for certain on all of them.
Now, 4H for my 4th gen is a different story. As soon as you shift to 4H you can feel a driveline buzz immediately start. The front driveshaft being shortened for this platform vs the 3G I guess is just not happy. Annoying because I wanted to convert to full time 4WD, but with that issue I can't really do so. I've seen too many others say theirs does the exact same for me to bother trying to fix it at the dealer. Not worth my time to be told it's normal anyways. I did delete the ADD in my 3rd gen which made the front driveshaft spin all the time, and it was perfect. I never had a single issue with that setup, and I liked the extra reliability of parts always being ready to work.
