Big Dawgs Toyota Tuning
Quez
Nashville
www.bigdawgstoyotatuning.com
Just got my 74Weld upper control arms for my 2025 TRD Pro, and I wanted to share some first impressions before getting them installed.
Right away, the first thing I noticed is how incredibly well made they look. The machining, finish, and overall attention to detail are obvious immediately. Everything about them feels premium, and they really seem like a top tier product. They don’t come across as just another aftermarket UCA. It’s clear a lot of thought went into the design. It’s also really cool that they’re CNC machined. Every part of them caught the attention of everyone at the shop.
One of the biggest advantages of these is that they’re fully adjustable without needing to remove them.
In the pic below, I had the shop owner hold them next to an Icon UCA. If you look at the angle of the arm where it leads into the ball joint and compare the Icon to the 74Weld, you can tell 74Weld put a lot of thought into the design. The picture is a little blurry, but you can still see the difference.
2024 Tacoma Just landed... 74Weld UCA’s 44758-4f925dfc4851afd6a94999e9a59a5ce9
The Icon has more of a straight-line angle coming off of it, while the 74Weld arm has a slightly concaved shape.
Why does that matter?
If you’re running larger tires or wheels with a different offset, tire contact with the UCA becomes a major concern. That kind of contact can limit steering and obviously cause damage to the vehicle. The slight angle on the 74Weld arm appears to create just enough extra clearance in that area while turning if you were to run into an issue there.
The amount of thought that seems to have gone into each of their new pieces is honestly pretty wild.
Out of the box, the build quality looks excellent. The arms feel solid without appearing overly bulky, and the hardware and components all seem top shelf. In person, they honestly look even better than they do in pictures.
2024 Tacoma Just landed... 74Weld UCA’s IMG_2719
What stood out to me most right away is how purpose-built they seem for a serious suspension setup. The design looks like it was created with strength, articulation, and geometry correction in mind, especially for people planning to run a lift and actually use the truck off-road.
Obviously, I can’t say anything yet about ride quality, alignment, or real-world performance since they’re not installed, but based on first impressions alone, I’m impressed. They definitely feel like a premium part.
2024 Tacoma Just landed... 74Weld UCA’s IMG_2721
2024 Tacoma Just landed... 74Weld UCA’s IMG_2718
If anyone else is running these on a 4th gen Tacoma, I’d still love to hear your thoughts.
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
I'm still planning out my suspension but I'll probably get these in the malibu grey color. These guys are like a mile away from me and their products are probably best in class for the same or less money than the competitors.
Gear_yyc
I'm not sure how I feel about having a brass thread adapter in there. Definitely the weakest link.
Quez
Nashville
i was very curious about the Malibu grey color but could not find any examples anywhere
Quez
Nashville
I was told they make their portals in Malibu grey. It's just a little bit darker than raw aluminum.
I was wondering if that color was close to what it’d look like. I think that’ll look sick.
Will721
Quad Cities
Theres zero chance those are brass. Likely steel with zinc plating. Aluminum and steel don't get along very well, especially certain alloys. Probably zinc plated to prevent galvanic corrosion. Otherwise those threads would be locked up in the first year.
CT2M
Ian
Los Angeles
Any updates on your experience with these. I watched 74 Welds video on this product and am pretty interested in buying. Dobinsons are also in consideration.
Quez
Nashville
been running them for a couple weeks now and haven’t had any complaints. Hoping to get off-road soon & I’ll really be able to tell you after that.
