Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
bsquaredMTB
Ben
El Paso, TX
Do you happen to have pictures or video of the wiring using the pigtails. I'd like to verify I'm doing it right.
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
Absolutely, here is the link to our install video!
Please let me know if you have any questions!
Joe650
Joe
Wasilla, Alaska
Ordered mine and can’t wait for them to get here. I probably won’t get them installed until after the 14th though as I’m going out of town and won’t have time. Will post pics when I do install them.
DesertFast
DFW Texas
2024 Tacoma TRD OFF Road
The bolt hole for the caliraised is too small to accommodate the bolt from the baja designs. I emailed them and they blew it off.
I would not buy from them again. It wasn't clear on the website and I feel like they got one over on me. Now I need to buy a new bracket because I want to run the industry leader... not some obscure off brand.
SAR Taco
Seattle, Washington
2024 Trailhunter
Has anyone sourced replacement hood bolts? Particularly those installing both the CaliRaised ditch lights with the Redline Tuning hood gas strut? From what I've heard there's an 8.14mm difference to account for.
YOLOYO
Oregon
2024 Tacoma Trailhunter
A dremel could fix that.
bsquaredMTB
Ben
El Paso, TX
I was about to say I didn't need different bolts but then I saw that you needed them for the hood struts. Hopefullly you can find something that does the trick!
Cali Raised LED
Cali Raised LED
Jake
Fort Worth, Texas
4th Gen Tacoma
Do these brackets work with Diode dynamics SS3 pods? I have a pair just need brackets
Yep—they totally work with Diode Dynamics SS3 pods. The bolt pattern and size are compatible, so you’re good to go using just the brackets.
Cali Raised LED ditch light brackets (and most others they make) are designed with standard pod spacing in mind, so your SS3s will mount right up with no mods needed. Just slap ’em on and aim 'em. https://caliraisedled.com/products/ditch-light-mounting-brackets-for-2024-tacoma
