2024 TRD Pro Sunroof leaking
ejhenry001
ejhenry001
Eric
2024 Toyota Tacoma TRD PRO
Spoke with the service manager and he did confirm this is the way its intended to work - its related to the amount of pressure that can be put on the sunroof as it closes, since its closes up instead of down - any more pressure and it could increase chances of breaking the sunroof glass - therefore they put a water management system in place to assist on those car wash times or heavy downpours...would still love to hear from an actual technician or someone with Toyota corporate to confirm this.....
Will721
Will
Quad Cities
2025 TRD OR
It's not just Toyota, sunroofs have been built this way for around 50 years or so now as far as I've seen. They're designed to leak to an extent around the glass seal, hence why they have gutters and drains. Might be older but frankly I'm not positive.
Only one I've seen in person that didn't have drains was a 1974 Roadrunner. Really rare car, if memory serves one of around 800. It wasn't glass though either, and fun fact; it was also a hand crank.
rijc99
Has anyone confirmed our sunroofs have 4 drain holes? From what I can see the rail covers the tray where the rear ones would be if they exist. Unless I’m missing something in the design of the sunroof cartridge.
Izebluke
Jake
2021 Toyota Tacoma TRD Off-Road Double Cab
I had a similar moisture issue, and getting proper mold remediation made a huge difference because they handled the source, the cleanup, and the air control in one go. The whole process was way smoother than trying to piece things together myself, and the house finally stayed dry and clean.
