315 (C2) vs 35" (E2) WildPeaks
SirLeigh
North Carolina
2025 Tacoma Trailhunter
I don't have a ton of experience here unfortunately, and I'm having a hard time deciding between these two. I know as far as looks the size is super negligible, so it's mostly about specs that have me questioning myself.
I know the C's will be more comfortable on the road, which is a huge plus, but the 315's have a max PSI of 35 while the 35-inch tires have a max PSI of 65. Is there some reason that one or the other would benefit me? These things are expensive, so I just want to make sure I know what I'm doing before I buy them.
I don’t think the ride will much different either way.
Vidman
Rick
Mass
The 315 will be a lighter and a bit shorter tire. E-load will be a heavier and somewhat tougher tire for Offroad. I had 305/70/18 ko2s on my tundra and I put them thru hell with no issues, they were e-load. If your just doing the swap for looks the c-load will be fine
Dirt
Greg
Eastern OR
Vidman almost said it. It kinda depends on what your reason is for wanting different tires. Just looks is one thing, function might be something else. I ran taller 10 plys that I could air up a little more when towing our travel trailer, then air down when off roading, but the factory C's worked for normal use.
