400w anytime mod??
co425
Brandon
BMW Motorcycle
Has anyone done or found a plug and play 400w anytime mod for the 4th gen Tacoma yet?
Billy K
Billy
St Louis area
2025 Tacoma TRD Pro, 2008 Rubicon
Can you explain a bit further what you are trying to do here?
co425
Brandon
BMW Motorcycle
On the 3rd gen Tacomas the 110v outlets will sit at 400w at idle. As soon as you drive they kick down to 100w. There is a cable that you can plug in to keep your truck at 400w idle or driving. The 4th gen does the same thing for the 110v outlets. I have not been able to find anyone making a 4th gen cable to keep our trucks at 400w.
Billy K
Billy
St Louis area
Thanks. That makes sense. But why in the world would they limit it while driving when the charging system is putting out more?
Is yours a hybrid model or no?
co425
Brandon
BMW Motorcycle
Has never made sense to me either. Should be the opposite.
gofastdan
When I bought my truck a year ago I tried to work with the Anytime owner to come up with a solution. The inverter is similar to the one used in the 3rd gen but of course they had to change it just slightly enough that the wiring harness doesn't match. I tried to see if I could get it figured out but didn't want to start cutting my wiring harness and as soon as the Anytime guy heard the 3rd gen wiring was different and wouldn't work he pretty much ghosted me so I gave up trying. It's been over a year now so I'm kind of surprised no one has figured it out.
...and this is not the hybrid. The hybrid has a completely different inverter (although I believe it's limited when driving as well).
co425
Brandon
BMW Motorcycle
Well thanks for the heads up on that on. I guess I will not contact them then.
gofastdan
Wouldn't hurt to try. Like I said, it's been a year. It's odd that it appears the 5th gen 4Runner is still using the old inverter since the website appears to say that it's the same product as for the 2nd and 3rd gen Tacomas. If you scroll down there's a chart that says the 4th gen Tacoma takes the "4.0" kit, but I don't see that listed on the website. Maybe that means he's actually working on it though....
https://guildoutfitters.com/product...-guild-outfitters?_pos=1&_sid=73ad14425&_ss=r
co425
Brandon
BMW Motorcycle
Okay sounds good. I’ll shoot them a message
Reconsnake
Jake
Sacramento CA
2024 Tacoma Off Road Premium
Let us know if you get a positive response please. I'm also interested in an anytime 400w.
Versus78
Sebastien
Quebec
Tundra TRD 2022
Also interested a if anybody comes up with step by step tutorial on how to access the inverter and which wires to splice/ground.
Still cant understand why the inverter is limited while driving, as understand that the alternator provide more power when moving thanks when idling...
Versus78
Sebastien
Quebec
Tundra TRD 2022
I can't remember how I found the schematic with th wire colors it but basically you just need to cut a wire, and ground the end of that wire going into the inverter which is under the armrest. That tricks the inverter to always be in full power.
gofastdan
So, it looks like this may be it. However, the description is wierd, has all kinds of info not really related, or maybe I am misunderstanding? Link here 400W Anytime Harness for 2024+ Tacoma | Tacoma Lifestyle
I agree a lot of the verbiage doesn't match the product but it does look like the correct product for creating the 400w power anytime and in looking at Guild's website (who I'm assuming makes the product that Tacoma Lifestyle is selling) they now list the anytime mod for the 4th Gen Tacoma. Like Versus78 said, you can simply cut a wire and ground it if you know which one to cut, but I never figured out which wire that was and didn't want to randomly clip wires. Plus, with the kit you can potentially add another outlet in the front of the truck somewhere, which might come in handy.
