5 pin Power for Uniden R7 (Solved)
sparkytaco
Jeremy
2024 Tacoma Off-Road
Hey guys - I just picked up my '24 TRD Off-Road Premium. I need to connect my Uniden R7 radar detector. I was curious about this 5 pin adapter I see from dongar instead of running the add of circuit to the fuse box. Is the 5 pin an always hot setup or hot only when the truck is running? As in, I do not want to turn the radar detector on/off every time, so I am hoping it's hot only when the truck is running.
Dongar 5 pin
https://dongar.tech/products/toyota5pin?_pos=5&_fid=830aaaccf&_ss=c
5v USBA to 12v RJ11:
https://www.stickerfab.com/products...r-power-cord-universal?variant=40859490189423
Solved - I used the Dongar 5pin and then a USB to RJ11 adapter adapter above. It turns on/off with the car. No issues! Thanks!
2024 Tacoma 5 pin Power for Uniden R7 (Solved) IMG_5015
2024 Tacoma 5 pin Power for Uniden R7 (Solved) IMG_5019
2024 Tacoma 5 pin Power for Uniden R7 (Solved) IMG_5020
Pootklopp
Usa
2024 Bronze Oxide TRD OR
Thoughts on this 5pin to USBA?
Then a USB-A to RJ11 cable step up cable (5v to 12v)?
Update - I think I need 12v for the R7. I am curious if you have any tips here?
From my question on a dash cam thread
https://www.tacoma4g.com/forum/thre...ing-factory-pigtail-connector.3848/post-57916
sparkytaco
Jeremy
Thanks. I understand the need for the 5V to 12V cable. My question is still on the 5pin connector always hot or hot only when the key is on? I dont want to manually turn off/on the radar detector. Thank you!
Iqudayo
2024 Toyota Tacoma
Dongar 5 pin
That’s what I did for the radar and also connected the dash cam. Actually piggybacking the pig tails works great
