6 speed transmission fluid change
Sandeep1994
Taco4gt
I changed transmission fluid today . Drain plug and fill plug are very easy to access both on same side ( passenger ) and lot of space .
I used redline . Its day and night difference in shifting .
1st to second gear clunk is gone and transmission shifts very smooth .
. Oem fluid from factory was not bad either but with redline Mt90 you can feel the difference
2024 Tacoma 6 speed transmission  fluid change IMG_0211
norko
4th gen 2025 Tacom m/t to
Hmm, interesting, thanks for sharing, what led to making the decision? Is it preventive maintenance or the clunk you mentioned?
Sandeep1994
Sandeep1994
Taco4gt
Just normal maintenance . Truck have 30000 miles now so decided to do all fluid change differential ,Tc and transmission.
. Trasfer case and front diff fluids came out clean as new . Transmissions fluid was ok . I could have gone more without changing it . But rear differential fluid was bad when it came out .
norko
Oh , maybe I need to do the rear diff then, I think I saw someone else reporting about the rear diff fluid quality
