Advice on Towing Setup with Stock 2024 TRD OR Pulling a Small Camper
Go_Gata
Jay
ABQ, NM
2024 Tacoma TRD Off-road
Hey everyone,
I’ve got a stock 2024 Tacoma TRD Off Road and I’ll be towing a small single axle Forest River Salem FSX around 20 feet. It probably weighs around 3800 to 4000 pounds loaded. The camper has a rear slide out for a queen bed and is in decent shape, but not perfect. I want to make sure my Tacoma is well set up for safe and stable towing, especially for trips into the mountains like Taos and Colorado resorts.
So far it tows fine on smooth roads, but I’ve noticed a bit of front to back jerkiness on rougher roads.
I’m considering upgrading the tires and possibly adding something like Timbren SES or rear shock upgrades, but I’d like your input:
  • What upgrades do you recommend with this setup?
  • Is a rear spacer with shocks and Timbren worth it, can I just go Timbren SES for now?
  • Has anyone run Bilstein 5100s up front with Timbren in the rear and a 1 inch spacer? Would that help with towing balance?
I’m not trying to overland, just looking for more towing confidence and access to dispersed sites. Any advice from those with experience towing with this platform is much appreciated.
I do eventually want to go with a suspension lift like the 5160 + 6112, +25 offset rims and Wildpeak AT4s
Powhunter
Alberta
A proper anti-sway weight distribution hitch like the Blue Ox Sway Pro is absolutely THE first towing “mod” anyone should do to their tow rig.
What a properly set up hitch does is spread out the extra towing weight evenly across your braking axles. Adding air bags or Timbren’s could mask a potentially unsafe situation.
Now if you have a properly set up hitch and then want to do a levelling kit, I absolutely would not hesitate to add Timbren’s in order to prevent rear end squat.
Mtnbikes
Minnesota
Have you weighed your setup yet? Truck and trailer together and separatly, loaded like you’re on a trip with a full tank of gas. What is your tongue weight on that trailer? Have you exceeded the payload of your truck? No matter what you do to your truck you still need to be within specs of that vehicle. I would figure out your numbers first and then make necessary changes.
Dirt
Greg
Eastern OR
I've not towed with this Gen 4 TRD OR, but did a lot with the Gen 3. Do you tow all the time or just once in a while? What level of comfort and performance do you want most of the time? Does your pickup get you down the road when towing? If you look on some RV websites you'll find weight police are adamant that their way is the only weigh. When I towed with our Gen 3 we made sure that we had a tow package that included a transmission cooler, the weight distributing hitch and anti-sway were the right setup for our trailer weight, and we were mindful not to overload the front of the trailer (hitch weight) too much. If we were going to tow longer distances over rougher gravel, dirt roads we disconnected the weight distributing feature and took it easy, letting the OEM suspension work. Our last trailer weighed about 4K loaded.
