Alignment Specs after 5100 leveling
shuo
shu
Seattle
2026 TRD Off-road Bronze Oxide
I installed bilstein 5100s this weekend at the 1” (lowest) setting with a total lift of 1.25”. Just got back from the alignment shop and had to argue about the cam bolt torque specs. The tech said “I tighten by feel”. Then I started down the rabbit hole on alignment specs. Seems to drive fine but wondering if they just followed industry standards and not specific Tacoma specs.
2024 Tacoma Alignment Specs after 5100 leveling IMG_4569
TN_Tacoma24
Cody
Tennessee
2024 tacoma
How do you like the level? What wheels tire size are you running? Got any before and after pictures? Im looking into this myself.
co425
Brandon
BMW Motorcycle
If you had to argue about them using torque specs. You likely already have your answer.
Thank you for posting this as I would not have thought to ask.
TimC.
Tim
Ridgeway, VA
2024 Toyota Tacoma
The after specs look great especially camber. Zero to -1 will serve the outside of the tires well. I have the full TRD Pro suspension and the +1 camber killed the outside of my new tires. It drove great though.
RutsyBucket
Hunter
Carlsbad, CA
2025 Terra Off Road
Alignment tech is an idiot. 4th gen cam bolts are 206 ft/lb. My alignment guy torqued them to the 3rd gen spec - 106. The shit creaked like a 100 year old floorboard. Shocker: that all went away when I torqued them to 206.
shuo
shuo
shu
Seattle
I think it’s good for me. I also have two 60# sandbags in the rear of the bed. Stock tires 265/65/18 in the pic. Getting Nokian 265/70/18 so just 1” taller. I feel like the ride quality has also improved significantly
shuo
shuo
shu
Seattle
Yeh I went home and checked again. They lost a customer.
shuo
shuo
shu
Seattle
To me they feel like a significant improvement.
