Alignment Specs after lift/Aftermarket UCAs
trdedgar
edgar
texas
this is the 4th time I’ve gotten an alignment due to the outer lugs of my tires wearing down way to fast, got fed up with the issue and installed some upper control arms( for the 2.5 inch lift I’m running, more like 2.3 after front bumper) and Im wondering if theses new specs will save my tires or are they also messed up, and if so what specs would you recommend asking for, would appreciate it if y’all can post alignment sheets to compare and get a better understanding what I need to ask for
2024 Tacoma Alignment Specs after lift/Aftermarket UCAs IMG_4842
Ruckus
2025 Tacoma SR5
In my opinion, it's a pretty good alignment. I've found that unless you go to a very specialized shop, none of these people will give your alignment the attention you want.
Bringing that positive camber as close to 0 as possible is what will save the outer edges of your tires, but I don't think you're in a bad spot. Your specs are better than mine, and I have the same 2.5" lift with UCAs.
More educated members here may have other opinions.
fitsofrage88
ryan
Atx
2024 TRD Off-Road Premium
I would Double check your alignment per 4th generation’ taco with a 2.5” front and 1”rear lift follow
