BamaTrailhunter
Greg
Alabama
2026 Trailhunter
Hartman, Heavylunch, first, thanks for posting this. It's a great help to the rest of us. I do have a couple questions...
Is this the Retrax Pro you guys used, Retrax Pro with T-Slots
Where did you guys run the drain tubes?
Thanks again!
Greg
Hatman
Hatman
Jeff
Argyle, TX
2025 Tacoma Trailhunter / 2022 Bronco Badlands
Thanks again!
Greg
You are correct on the Retrax Pro with slots. There are drain holes that are already in the front of the bed that you can drill out a little bigger for the drain tubes. Personally, I just left the tubes inside the bed and don’t really care if water gets in. If I’m hauling stuff that can’t get wet I just put a tarp down first so any water would go between the bed and the tarp, thus keeping my gear dry.
BamaTrailhunter
Greg
Alabama
2026 Trailhunter
I was also wondering if these would work T Slot Nuts
Seems it might be a bit cleaner look with just the bolt head showing rather than the bolt and nut sticking up.
Hatman
Hatman
Jeff
Argyle, TX
Those will definitely work as long as your bolts are the correct length. The T-slots are 20mm wide so 18mm will fit. I’m guessing that the height of the wings will fit. They don’t provide that measurement nor the width of the section that comes up. The channel width is 10mm and it looks like these should be okay to use.
Gonzo
Richard
Ottawa, Canada
That looks great!! I like the dual channels on the cover. Which one is that?
It’s a U-Guard Tonneau Cover. I liked the dual channels also which was one of the reasons I bought it, but the interior T-Rails ones are too narrow for the cut ARB flanges. Here is a link to it. U-Guard Tonneau Cover
Stealth4GT
Arnold
NC
2024 Toyota Tacoma TRD off-road
Hey I was thinking about buying this cover and doing the ARB sport bar mod. Has this been working out well for you?
Hatman
Hatman
Jeff
Argyle, TX
It is working great. You will be surprised at how solid the setup is.
Rabbb
Robert
Boston,MA
2026 Tacoma Trailhunter
New to this forum, and love this thread - helped me decide on a new 2026 TH, thank you very much Jeff and everyone!
One question - on the back upper corners of the bed, the bed cap moldings indent a bit, between 3" and 11" from the end. And the deck rails don't go all the way to the back and stop about a foot ahead of the end.
Not sure if these two things are unique to the 2026 or TH, but are they issues when installing the Tonneau covers? All the cover products (including Retrax retractables) show the bed caps and rails as extending straight all the way back and with no indent.
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_4240L
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_4246L
Hatman
Hatman
Jeff
Argyle, TX
My rails looks the same on the 25 so you should be good. You can see on my photo that the Retrax attaches in the 2 spots where you see the silver track bolts.
2024 Tacoma ARB Sport Bar + tonneau cover combination -- how to have both (my solution) IMG_3372
TRBO4X4
Jason
Tucson, AZ
2026 Toyota Tacoma Trailhunter
FWIW, I took the Bak Revolver X4TS from my 2025 TRD OR and put it on my 2026 Trailhunter without issue. I removed the ARB sport rack of course. No issues or concerns with the rails ending where they do from me.
Turbo2Pete
Pete
NY (not the blasted City!!!)
'25 Trailhunter
I’m wondering the same thing about the tool. All I have currently is a multitool. I hope I can find a friend who will help me cut with the right tool.
Bit late to the thread - but I figure it might help newer readers (and you if you haven't gotten this done!)
Hit Harbor Freight, you can get a 4 inch grinder for under $15 (been a while since I looked, we used to get them for $7, they'd last 4-6 hard hours and get tossed when they cooked) it'll get the job done, and if you don't overload it, it will hold up.
https://www.harborfreight.com/43-amp-4-12-in-angle-grinder-with-slide-switch-58089.html
lauren01
Lauren
Ventura, CA USA
2025 Tacoma Trailhunter LB
Thanks for looking out. I’ve picked up a beefier version at Harbor Freight in hope of getting that cutting chore done and another project (house type). Got one with the paddle switch and more power. Going to get a few larger clamps for my work table since those are on sale tomorrow.
