Best tonneau cover?
dchemphill1
DrRooRoo1!
2020 Jeep JL Rubicon , 2023 Subaru Xtrek and 2025 tacoma TRD Sport
Is anybody using the Gator soft tonneau cover?
lane47
Lane
Tennessee
2025 Tacoma
I have Gator SRX soft tonneau. No water so far, after 6 months, 9000 miles, a few car washes. I park in a garage at home, great price, easy install.
Speedy Gonzales
San Diego
Tacoma SR5
Gator SRX soft cover is $219.00 I bought an exactly the same cover on eBay for $90.00 including shipping.
Ironhide
Lodi, Ca
ā€˜24 SR5
I have the Gator as well. 1 year, no issues. I like that it sits lower than most soft covers.
MustardTiger
TacoMAX/SDuty/Dmax
I went with RealTruck’s BAK Revolver X4ts
I wanted something low profile, that didn’t completely block the rear window or infringe on bed volume, t-slot rails and compatible with a bed rack. Really happy with it.
I have the same cover, X4TS. While it's ok and accomplishes some pretty key metrics (full bed access, doesn't block the back window, t-slot rails) there are a couple things to note:
-It leaks water pretty bad, even with trying to seal it up with extra gaskets and foam tape
-If you haul full sheets of 4x8 sheet product, the latching mechanism on each rail is rather large and intrude against the bed opening width; basically, it will won't allow a sheet of plywood to rest against the (closed) tailgate. You'll need to have a couple 8ft 2x4's underneath the elevate the sheets so everything clears those rail latches
-The more you roll the top and store it in the rolled-up position, the more the rubber strip gaskets along the outer edges of the cover top wear and mark up. Unfortunate this area isn't more durable
Otherwise, ya, great cover...
bsquaredMTB
Ben
El Paso, TX
Has anyone tried that new ez off from retrax. I know it's super pricey but I like the idea of being able to take off the canister in those rare occasions when you need the entire bed. I'm really curious to get someone's real world review
