Broken window position sensor- dealer wont warranty
rchrds
TN, USA
2024 Trailhunter
Well, for a while now my Trailhunter has thrown up a message when you shut the vehicle off that one of the windows is open. I was sure it was a sensor on one of the windows, but couldn't figure out which one. Finally we took it to our local dealership, where they charged me $180 diagnostic fee, and then told me that I had somehow manage to break the sensor (inside the door panel somewhere attached to the actual window glass.) I declined to have them fix it, as I feel like it should be fixed under warranty. What are my next steps?
StreeTaco
TN
2024 Tacoma TrailHunter
Your service dept is full of clowns for charging you for a diagnostics fee on a warranted item. Next Step: get your money back!
Somehow you managed to break the sensor,, Huh? I would have whomever said that fired
There's a way to elevate this to Toyota. And no, I don't know how.
glk21c
MD
2007 Tacoma
Did you have audio work done in the truck? which could give them a reason if it looked like behind the door panel had been messed with.
rchrds
rchrds
TN, USA
2024 Trailhunter
Nope. I have a seat delete, which may have spooked them. But never had the doors apart.
You need to call Toyota and file a complaint. Did they explain how they believe you broke this part? The truck is under warranty—this sounds like another classic case of service department incompetence.
bking
Bernie
2024 Tacoma TRD Offroad
Find another dealership, but definitely call Toyota. You need that diag fee back.
rchrds
rchrds
TN, USA
2024 Trailhunter
Any idea where I find this number?
inlandsmog
Craig
Bristol, TN, United States
2024 Tacoma TRD Off Road Hybrid
First Contact the service manager then contact the general manager then contact the regional manager then contact corporate then post everything on social media.
Delta1Seven
1-800-331-4331
This is the Toyota number. Call them and tell them you want to create a case in regards to this issue. By creating a case, they will assign a case manager to you who will 'work' on the issue. If it's anything like my last issue, they make you feel like they are taking care of you, but in reality it seems like they try to string you along as long as possible before actually helping. I called daily and continued to ask for updates with my case manager until they actually cared.
I would also request for them to refund your $180 diag fee. If they say this isn't a warrantable item, then good, have them prove it was broken under wear-and-tear or misuse. They won't be able to because it wasn't! There is no way you could damage that sensor (considering it's not even accessible).
And I would stop using the word 'broken', but insist it is 'defective'.
I've had 2 Lemon vehicles this year, 1 tundra and 1 GMC Canyon. Don't let them make you pay for this...
inlandsmog
Craig
1-800-331-4331
This is the Toyota number. Call them and tell them you want to create a case in regards to this issue. By creating a case, they will assign a case manager to you who will 'work' on the issue. If it's anything like my last issue, they make you feel like they are taking care of you, but in reality it seems like they try to string you along as long as possible before actually helping. I called daily and continued to as for updates with my case manager until they actually cared.
And I would stop using the worse 'broken', but insist it is 'defective'.
Great advice!
