Custom aftermarket OEM Aux Switches - where to buy?
MHG
Mark
Long Island
2025 TRD Offroad
Has anyone found any place that sells custom (or something other than aux) OEM fit Aux switches? I see plenty of companies that sell their zombie or Bigfoot switches but they don’t connect to the factory harness connectors. I wires up my Aux1 and Aux2 switches and I am looking for new switches.
Seems to me that if the caps themselves can pop off and be replaced that would make it easier since not everyone is putting (let’s say” ditch lights on the same aux switch.
MHG
MHG
Mark
Long Island
2025 TRD Offroad
Unfortunate they are not compatible both the OEM harness. These are for after market wiring and or cutting off your factory harness connectors.
Also keep in mind that AUX 1,2,3 and 4 (if you have a pro or trailhunter) all have slightly different connectors on them. So if a manufacturer was to sell them they would need to list which Aux switch a given switch will fit.
MHG
MHG
Mark
Long Island
2025 TRD Offroad
Well, through my factory ones underneath the old laser printer. I ordered a switch from China that’s blank. I’m gonna see if I can’t laser print new caps for it I guess.
2024 Tacoma Custom aftermarket OEM Aux Switches - where to buy? imag
MNTBKR
Luis
Central, FL
I ordered from https://www.switchboss.com.au/colle...switch-suit-toyota-square-white-led-41-styles They have a momentary switch that is meant for garage door openers. I have the poverty spec TRD OR and I didn't just want my garage door opener out in the open, I was inspired by another member that did the same, now my garage door opener lives in the cubby on the side of the dash and I can operate it with the switch on the dash. Also they have a white light option that is not a perfect match to the OEM white but I feel it's better than having a blue light like I've seen from other sources.
