- First Name
- Corey
- Joined
- Jul 13, 2024
- Threads
- 16
- Messages
- 124
- Reaction score
- 75
- Location
- Plant City, FL
- Vehicle(s)
- 2024 Tacoma Limited 4x4
Ever since I decided on a winch, I've been looking for a solution that would give me several points of direct access to the battery, since I already have a compressor mounted in the rear.
I knew with the winch bumper I was getting, I'd also need somewhere for a relay for the 20 inch light bar to live.
about a month ago I started buying parts, and looking for spaces under the hood to mount a large(ish) power distribution station. I first started with a panel that mounts on top of the fuse box next to the battery, but with the few prototypes I made, I barely had enough room.
I then moved on to a plate that attaches to the battery hold down strap, which is what you see below. I have to drill a second hole in the strap, so there would a nice locked down plate. I used flat head screws so the attachment to the strap wouldn't cost me any layout space, and after a few prototypes cut in 1/4 acrylic, I landed on this design last week.
It has:
4 post negative bus bar with 4 8mm posts and a ton of 4mm screws
4 post positive bus bar with 4 8mm posts and a ton of 4mm screws (one of those is feeding the Blue Sea block)
6 position Blue Sea distro block for lower amp power needs
4 position relay bracket
bus bars are connected by 2 gauge wire.
Acrylic is the easiest material for me to prototype, I can cut it on the laser cutter in my shop. I"ll probably have one made in powder coated steel by SCS, but I might stay with acrylic since it's not conductive. It's still a work in progress but I feel like I'm 90% there with this one.
It has:
