Dobinsons C59-823V installed on Trailhunter with 800lbs constant weight, 2.5" positive rake
eatsomeonion
2025 Tacoma Trailhunter | 2021 4Runner ORP
My goal was to lift the rear and level the truck after adding a bunch of weight, maybe with a tiny bit of rake. Stock springs were sagging pretty bad.
After talking with Dobinsons, they recommended C59-823V. Here is what they told me:
Hybrid models will yield 1" less lift
C59-823V (55mm - 2.25") 880-1210lb Load / (30mm - 1.25") 1400-1600lb Load
Which means I should get ~1.25" of lift, pretty close to stock Trailhunter rear height.
However after installing the springs and taking some measurements, I ended up with +2.5" rake. All heights measured from center of hub to fender:
Front: 23"
Rear: 25.5"
This is with 800lbs of constant weight. When we add our usual trip gear (2 eMTBs at 50lbs each + riding and camping gear), I doubt the rear will sag enough to level out.
I hope the springs will settle a bit after some driving but I doubt it. I might throw on a Peak Suspension or Westcott Designs spacer lift up front. Wasn't planning on lifting the front but at least spacers are cheap and I can always remove them later if I add more weight to the rear.
2024 Tacoma Dobinsons C59-823V installed on Trailhunter with 800lbs constant weight, 2.5" positive rake rak
