Door Panel Drain Plugs Problematic
JED
Jeff
Southern Tier NY
2015 Tacoma TRD Sport
Had my truck parked on a significant incline recently and noticed water slowly dripping from a couple doors. It hasn’t rained here in over a week.
pulled associated door panel plugs and drained approximately a pint of water from each door. I’m guessing the plugs are meant to prevent insects from nesting.
I opted to pull the remaining plugs to allow proper drainage.
Brent@ANParts
Brent
www.autonationparts.com
Ford Bronco
Some vehicles come from the factory with the plugs installed, and subsequent service bulletins call for them to be removed. So there's a chance they weren't suppose to be there anyhow. Shouldn't have any issues without them.
Do you have a copy of that bulletin?
JED
JED
Jeff
Southern Tier NY
From what I saw on an internet search, the service bulletin (applying to all Toyotas) they want (1) of the (3) removed from each door.
Interesting. I'll have to see if I can find that, cause my OR has all 3 plugs on both sides.
john877
Severn, MD
2024 TRD Sport
I had water sloshing in the rear passenger door, I figured it was just a stopped up drain hole. I was surprised to see plugs in the drain holes. I saw somewhere online that toyota said to just pull the rear plugs on each door if you have water issues. I just pulled all of them, can't imagine why you wouldn't want the doors to drain.
SnowmanJPS
Halifax, NS
2025 TRD Pro
I wish I knew more as to why they put them on, and only offer to remove one
JED
JED
Jeff
Southern Tier NY
Said to be dust and insect protection. Here in the NE freeze thaw and salted road corrosion would be a much higher priority I would think.
JED
JED
Jeff
Southern Tier NY
SnowmanJPS
Halifax, NS
2025 TRD Pro
I live in Nova Scotia and we salt the crap out of everything here, I may put them back in for winter but I never had them on any other vehicle
JED
JED
Jeff
Southern Tier NY
Same here in upstate NY. The problem I believe with having them installed in the winter is freeze thaw and corrosive salt residue find its way to the panel from car washing. Had 4 other Tacomas without these plugs. Never had rust on any of them
