- First Name
- Rudy
- Joined
- Feb 13, 2026
- Threads
- 12
- Messages
- 226
- Reaction score
- 187
- Location
- New Mexico
- Vehicle(s)
- 2026 Tacoma TRD PRO
Looking for you guys thoughts, RPM/Friction/Heat vs. Engine load. When you're in tow haul mode and the vehicle stays in a lower gear running around 2k rpm your engine load is less, sometimes almost half the load if your in normal mode and running around 1500rpm.
Higher rpm/lower load equals more rpm, more friction, more heat, one advantage besides less load on your crank and tranny is the additional heat helps to burn off liquids that dilute your engine oil.
Lower rpm is less friction and heat but more load and possibly more ingredients that accumulate and dont get burned off.
Looking for thoughts from some of you rocket surgeons??
