- First Name
- Rick
- Joined
- Aug 27, 2026
- Threads
- 3
- Messages
- 107
- Reaction score
- 77
- Location
- Monument, Colorado
- Vehicle(s)
- 2026 Toyota Tacoma Limited Hybrid
I have a few questions after driving my new Taco from Colorado to Tennessee (1,200 miles) to visit family.
-Is hard shifting normal? Like when backing up out of the driveway and then putting it into Drive can, sometimes, cause a noticeable thud. I only notice this when putting it into drive after backing up. (I do stop all the way before shifting into drive.)
-Since she's our 4th Toyota Hybrid, I do worry about the 12-volt battery because I've seen the issues caused when the 12-volt gets low....our Prius and Corolla Hybrid do NOT do a good job on charging the 12-volt while driving and my battery tender has gotten a LOT of use the past few years. Does the screen display the current state of the 12-volt? (I'd like to know the current voltage since I know anything lower than 12.4 volts can cause troubles.....my wife's Corolla hybrid would not start one morning and I tested it and it said it was at 12.2 volts.)
-One dislike is how I lost the underseat storage in the rear because of the traction battery. But glad it only has 3 plastic clips I release to lift it up for access. (Like to test and charge the 12-volt battery if it needs it) But glad the 12-volt looks pretty beefy even though it has just 600 amps of CCA....but the hybrid has no starter so the CCA isn't really relevant.
-I am glad the engine air filter is big.....actually, it's the same filter I had in my 2014 V-8 Tundra. How often does that filter need changing? I know it sucks down a LOT of air for the turbo.
-I did add a cool storage tray behind the 14-inch screen and the other, small one, under the driver's air vent and I keep the FOB in there but SO glad the truck sounds annoying beeps when I forget to grab them when I get out. (I've learned to not ignore the beeps.)
-In my V-8 Tundra, when driving across country, you'd better be stopping to refuel when she's at 1/4th of a tank but don't really need to stop right away with the Taco....when she says 75 miles to empty she will only take about 12-gallons...so there's about 6 gallons, still, in there. We don't mind stopping, anyway, because I get to clean off the bugs all over the windshield.
Overall, this truck is great.....took her through a car wash and then opened the Toyota hard tonneau cover to check for leaks and not a drop. Will be driving home the next two days and expect a lot of rain so will get a better water check. (Will put our gear in the bed in big, black bags just in case water gets in there.)
