Kinetic Rope Size
astroboy
astroboy
Southern California
The reason why I say 20 ft is not enough, kinetic ropes will spring you out of a hole and towards the vehicle that pulled you out. Plus, when you're looking over the hood of your vehicle while getting towed out, you're going to seem very close to the vehicle in front of you. With 30 ft length, you could at least see some ground between the back of your bumper and the front of their hood
You also get more stretch (aka kinetic energy) out of 30 ft than you do from a 20-ft kinetic rope
Makes sense! Just want to make sure that I am getting the correct thing, for these ropes are not cheap.
DesertFast
DFW Texas
2024 Tacoma TRD OFF Road
I keep editing this post to try to keep it tight but don't buy kinetic rope unless you know exactly what you need. If you don't know, you don't need the rope I assure you.
What if you only have 15 foot to get a quick pull in? You'll never get 30 foot tight without using the rope incorrectly. What if the truck you're trying to pull out is way heavier, or way lighter? It's a mess.
Just buy a winch.
24Trailhunter
Jared
Tehachapi
His original question was what size and length kinetic rope to get. Hopefully it's common sense that if you have only a 15 ft runway that you don't use a 30 ft kinetic rope. That should go without saying. A winch is always a good option, but considering his inexperience, a kinetic rope may be a better option. You can easily rip your car apart if you don't know what you're doing with a winch. So in hindsight, you are correct. But all in all, there will always be different scenarios or situations to overcome in regards to recovery. At the end of the day, it takes some knowledge and some common sense as well as some research to figure out the different kinds of recovery tools that should be used in different scenarios. In no way shape or form is a kinetic rope good for all recovery scenarios. And at the end of the day, you should have multiple different types of recovery options on board, especially if you're wheeling solo. I would suggest a winch first and foremost, followed by a kinetic rope and soft shackles, followed by a tow strap, followed by some recovery boards or maxtrax, followed by a shovel and pieces of wood to lay down over your tires etc.
Dirt
Greg
Eastern OR
With all that, and a handy man jack you'll be the most popular guy in the neighborhood. :cool:
Pappy
Jon
Intermountain West
From JM Rigging:
"When choosing a recovery rope it is best to figure a rope that has 4 times the capacity of the weight of your vehicle. For example, if your vehicle weighs 5,000lbs a rope with at least 20,000lbs capacity or more would be required, our 3/4" line rated at 25,000lbs would be an excellent choice."
https://www.jmrigging.com/product-page/3-4-kinetic-recovery-rope
I own at 7/8" rope, only because I wheel with FZJ80's.
Pappy
Jon
Intermountain West
Is rope better than strap?
Two different recovery tools. A kinetic rope is used when somebody is mired up. Sand, snow, mud. A recovery strap is good for moving somebody who is not mired up, but just needs a gentle tug to get them up, or over, an obstacle. Recovery straps are also good as winch line extensions.
Kinetic ropes are used violently. Recovery straps are used gently.
Pappy
Jon
Intermountain West
Are you happy with the JM rigging brand?
Let me put it to you this way. I have the following from JM Rigging: 2 soft shackes, 2 winch ropes (one on a Warn M8, the other on a Warn xd9), kinetic (bubba) rope, a winch extension rope, and a recovery pulley.
Jim is a great guy. You can order online, but give him a call (hint, hint). You will need to leave a message (he says why), but they call back quickly.
Nuff said.
24Trailhunter
Jared
Tehachapi
Are you happy with the JM rigging brand? I was considering this one in 7/8" as that what others seem to recommend as well. I've never used this style rope before. Is JM a good brand? I know Bubba is the most known, but that doesn't always mean the best, and it seems like you may be paying for Bubba name (JM is $190 and Bubba is $280)
The 3 brands that I would chose from are:
Yankum
Bubba
SandyCats
I have Yankum and love it. If you have ever heard of Matt's off-road recovery on YouTube, Matt has yankum build his ropes for his recovery business. Very high quality!
RESQCAT
Dennis
North Bend, WA
2024 Toyota Tacoma Trailhunter (very modified!)
Two different tools. A strap is for towing. A kinetic rope is for recovery.
Not precisely correct. There are tow straps and tow ropes... and kinetic recovery straps and kinetcic recovery ropes. Each has their intended purpose.
ARB makes a fine kinetic recovery strap. One reason to consider a strap instead of a rope is footprint... a strap is more compact and so more easily stored. However, it stretches about 20% of its length while a kinetic recovery rope stretches about 30% of its length. So when using a rope you get a smoother and more gentle release.
If you practice your recovery technique, either will do the job for you. But you need to use them correctly... in SAR we essentially try first pull by staging the pulling vehicle with a little play in the rope, then move forward at about 3-5 mph. If that does not free the vehicle, then maybe a bit more on the throttle to pop the towed vehicle out. There is more to the technique than that, but you get the idea. The videos that show folks cramming the accelerator down do not do justice to the proper technique using a kinetic rope. And... they can do more damage than good.
RESQCAT
Dennis
North Bend, WA
Thanks for the info! Yeah, they are significantly cheaper than the big Bubba name. Which isn't bad, just tells me they may just be more honest.
I am new to offroading, and have pretty much no gear yet. Hoping to get the basics, and then need to find someone to go on some trails with!
I suggest three (3) soft shackles. Ideally you put one on the towing vehicle with a centered towing shackle, to make a V... spreading out to a recovery point on each side of the towed vehicle... if you can. The other application would be to hook up on the same side of each vehicle to keep a line.... you do not want to cross load or you risk moving in the wrong direction and having an inefficient pull.
EatMyTaco
Murica
2026 Tard OffRoad
Yankum
Bubba
SandyCats
I can't say from the others you have posted, so not saying they're good or bad, but the bubba ropes we have at work have worked well. Seemed high quality. Weren't cheap though.
RESQCAT
Dennis
North Bend, WA
Thanks. Been doing recovery for awhile now... both military and SAR, as well as overlanding.
There is lots of gear out there, some good, some not, some used very seldom, with lots of opinions on what is "best". I find that if I have it with me it is "best". Garage gear doesn't do much good, and space is at a premium as is the pockebook.
All the best.
