Loading...
Berno
Laguna Beach
2001 Tacoma
Check out the OZ Tech Burro utility slide or Kaizen Source Taco Mounts. There are a lot of options out there for Packout boxes.
I went with two gray Plano tool boxes from Home Depot. Weather tight. Less than $20 per. Easily moveable and tuck in cleanly under my retractable tonneau cover. When the rubber mat is in place, they don't move a cm. When it's not, they can slide around a little bit depending on a hard turn or bump. One contains more emergency gear like gloves, blankets, etc. the other contains more recovery gear like inflator, straps, soft shackles, etc.
It was the best solution I could find right now for something that maximized the space under the cover roll without extending past it.
Viper_00
Walter
VA
I got one of these swing out boxes. Takes 2 seconds to remove when I need more room. Also comes with a lock/key
2024 Tacoma Loading... IMG_4594
