New RokBlokz mud flaps - AWESOME!
kennyk
Kenneth
Renfrew, PA
2024 Toyota Tacoma
They are the best option for Tacoma. Looks nice! I painted the bolt heads with flat black plastic dip.
What's the name of plastic dip? Where'd you source it from?
Sancheesy
Shawn
Ontario
I'm liking how flat these are. I just put 33's on my OR and at full lock going over a curb entrance there is a little rub on the passenger mud flap. Maybe these will help that.
kennyk
Kenneth
Renfrew, PA
2024 Toyota Tacoma
They're flat as a pancake and when you tighten the screws, it really pulls it into the contour of the wheel well.
Yotota
SW WA
24 TRD
I had issues with mine, especially the hardware - it was all too long. I wonder if they fixed that? I emailed their team but never got a response. The long screws were breaking the OEM plastic inserts in the fenders. And the long machine screws were gouging the OEM fenders.
Mine also didn't sit level but I got over it. The big design issue with mine was that the rears are 1" higher off the ground, and tucked into the truck 1", compared to the front.
Rich
Rich
PA
2024 Tcoma off road
How did you go about painting the screws? Any pics?
ridetime
Oklahoma
I masked off enough area around the screw heads to keep it off the paint and sprayed them. The flap is plastic so any overspray is easy to peel off.
2024 Tacoma New RokBlokz mud flaps - AWESOME! IMG_1258
Rich
Rich
PA
2024 Tcoma off road
Looks good. Going to give it a try. Thanks
justintseale
Jinhtown
Houston
2024 Toyota Tacoma
Two thumbs up as well. I did shorten my flaps because I felt they were too long. I cut them right above the embossed logo.
What did you use to cut them? Was the cut finish clean?
Put KO3s 275/70/18r on OEM wheels recently, about to add 1” spacer so tires should be flush with outer most part of the top of fender. Ordered these - waiting on delivery.
I don’t want these new mudflaps sticking out past the tire so was wondering about trimming them if needed. My tire, rim, spacer combo might be about the same as your offset?? I should be at +30mm equivalent offset when I finish.
Mini2nut
2026 Tacoma Trailhunter
I carefully cut them with a cutoff wheel.
